abs problem
Old Apr 8, 2019 | 07:10 AM
robert elmondalek's Avatar
Default abs problem
Hi guys, i have audi a4 b9 2017 premium ultra tech with virtual cockpit, my mechanic take out the four wheels, and release the abs system, after put everything back and new brake fluid the brakes doesnt work, when you press the break in the first time its going deep, them after two press the car start break, some guy came with scanner and tried to find the abs but he cannot see it, someone can help me?
Old Apr 8, 2019 | 01:19 PM
CFM567's Avatar
The ABS system sounds like it just needs to be bled by a mechanic with the proper equipment.
Good luck!
CFM
Old Apr 8, 2019 | 10:48 PM
PghRich's Avatar
Doesn't sound like an ABS problems, sounds like a problem with the braking system as a whole. If you're not getting braking forces, ABS certainly isn't activating. If pumping the brakes helps, then it's likely air in the lines - ask the mechanic to properly bleed the brakes after changing the fluid.
This will not show up on a scanner.
(Actually, ask a *different* mechanic. This is brake maintenance 101 - I wouldn't trust a mechanic that couldn't bleed the brakes, and obviously didn't perform a test drive, to do any more work on my car)
Old Apr 10, 2019 | 05:20 AM
Yesterday i was with other mechanic, e bleed thew brakes again, check the master cylinder, and the brake booster, still no get pressure from the brakes... 1 month ago the painting guy release the computer and the abs module to put a new fender, after the work e connect everything and the problem came...
Old Apr 15, 2019 | 04:23 AM
last week the mechanic came, the car didn't start, after several hours we found the brake light switch together with the master cylinder ad the car start, we tried test the master cylinder loosing the pipes that came for the master cylinder to the abs and press brake, very low pressure, i order a new master cylinder, the reason that suppose made the master cylinder damaged was a few weeks the pipes was loose and have no brake fluid then the seals dry and damaged, sound right??? lets see when the new piece arrive.
Old Aug 12, 2019 | 02:51 PM
YULS5SB's Avatar
Did you got this resolve? What was the real issue?
Old Aug 12, 2019 | 02:55 PM
Nope. Still the problem. I change the master cylinder bleled the brakes scan the car nothing solve it. The problem its you cant shift from parking due when you press break said "please press brake to shift" or something like that. Means the sensor its not sending the signal to release parking to drive or reverse or neutral.
Old Aug 13, 2019 | 08:31 AM
SchwarzS6's Avatar
This problem is usually caused by the brake light switch. In most cars this is a mechanical switch mounted to contact the brake pedal arm just above the pedal. That is where I would start.
 Michael S. Palmer
yota-toy
Jun 3, 2009 07:28 PM
JMS4
Jul 27, 2002 02:33 PM
TTjohnny
Sep 26, 2001 04:34 AM
Mitch S
Apr 4, 2000 07:23 AM
Dave
Feb 20, 2000 02:15 PM
