Battery problem
If you change the battery with the same kind (type/size), then no, lack of changing the serial number is not going to mean much. If you replaced it with the wrong kind of battery, well, that's on you.
"the battery isn’t holding charge and keeps draining", how do you know this? What measurements have you been tracking to confirm this? And if you only do short drives with lots of stop start, good luck ever getting the battery back to 85% SoC.
But you can't have a "car said battery problems and then turned off" and "battery and alternator are good". Get VCDS and acquire some actionable information.
I have a ODB II will that help?
As for "I have a ODB II"? What? You have a OBD-II device? Or were you trying to say OBDeleven?
