Does a new battery need to be coded?
Old Feb 15, 2023 | 11:05 AM
Pelican Pete's Avatar
Default Does a new battery need to be coded?
I thought I read something here about needing to code something into the car when the battery is replaced. But now I cannot find that post, and I don't remember the details.
My "new" car should be arriving tomorrow. And while it's in very good condition, I suspect it is still on the original battery. So I will likely be replacing the battery pretty soon.
Is a battery covered under CPO? (I doubt it but figured I'd ask)
Ideally I'd like to get an AGM battery.
Anything I need to know?
Thanks
Peter
Old Feb 15, 2023 | 12:08 PM
dirtyjack's Avatar
this has been discussed in a few threads
https://www.audiworld.com/forums/a4-...3048474/page2/
https://www.audiworld.com/forums/a4-...et-ok-3032534/
Old Feb 15, 2023 | 12:41 PM
LightningTruck's Avatar
Yes. Do you have a VAGCOM or OBD11 tool?
It needs to be AGM.
I have my eye on this one:
https://www.fcpeuro.com/products/aut...dyssey-94r-850
Or this one:
https://www.walmart.com/ip/seort/40685088
Old Feb 15, 2023 | 02:03 PM
142 guy's Avatar
As noted, yes to adapting the charging controls for your new battery. The car will run without the adaptation; but, your new battery may not stay new for very long
OEM battery on the B9 should be AGM and you should replace with AGM. I don't know about pre B9 A4s; but, the B9 makes fairly heavy demands on its battery. Stand around your B9 after you turn it off and you can hear stuff running (after run cooling pump, radiator shutters). The parasitic loads are significant. Since you live where it gets sort of cold, if you do much short hop driving you might want to consider the addition of something like a Ctek charger (Ctek just because that is what Audi in Canada buys and sticks an Audi sticker on then charges double price at the dealer).
Audi S4 Battery charger - 420093050D - Genuine Audi Accessory (audiaccessories.ca)
Old Feb 15, 2023 | 04:20 PM
SchwarzS6's Avatar
Make sure you really need a new battery before you spend the money. I live in CT also and I have owned a LOT of Audi's. I think I have only replaced two batteries and I often ran cars for 120,000 to 140,000 miles. Because the battery is in the trunk it is not exposed to the heat of the engine and heat is the killer of batteries. Yes the A4 makes a heavy demand on the battery but it also has a very sophisticated power management system and I suspect the battery will last quite a long time.
Old Feb 15, 2023 | 09:31 PM
PghRich's Avatar
There are YouTube videos describing the installation and adaptation process.
Old Feb 16, 2023 | 06:42 AM
gooberman's Avatar
Mine is coming up on 7 years old and hasn't given me a problem yet. I think you might not need one yet?
Vegas-roadster
TT (Mk3) Discussion
12
Jan 30, 2024 06:29 AM
brettfletcher79
Q7 MK 1 Discussion
Sep 15, 2021 08:00 AM
Mr-K84
A7
Jul 10, 2021 11:16 AM
djrx
Q5/SQ5 MKI (8R) Discussion
Jan 24, 2019 11:39 AM
