Electronics issues compilation.
I know some of these can be addressed utilizing a program that accesses the system but it doesn't seem like a lot of these should be that invasive.
1) When viewing a map in the Virtual Cockpit the mousewheel on the steering wheel spins in the opposite direction than I would expect for zooming in/out. I get this might be preference, but it feels so completely foreign in its current config that I can't be in the minority on this.
2) Engine Autostop feature cannot be disabled by default (correctable via a program but not using the native interface).
3) Bluetooth audio for a phone will be disconnected when a cabled connection is made (understandable), but upon exiting and reentering the vehicle Bluetooth audio is left disconnected until manually connected again. Once established it should auto-connect to Bluetooth audio and only disconnect when a phone is cabled.
4) The amount of equalization in the audio is abysmal, especially with the upgraded B&O sound system. Single band equalizers for bass and treble is just really weak, and the removal of the subwoofer equalizer (which I saw on earlier models) is puzzling.
Start/stop doesn't bother me but an option would be nice for those who don't want it on.
I can't confirm 3 but I'm pretty certain that it does reconnect. It could be phone or app dependent. I've sure that this is what happens on start.
I'm not sure if I've even seen a subwoofer equalizer or cross over function in any vehicle I've seen (within reason). Individual EQ would be great but I appreciate the simplicity.
Why would you open the door first before unplugging your phone?
I would think the easy solution is that if you turn off the car (and open the door) before unplugging your phone, then upon returning to your car the next time, you should plug in your phone before starting the car.
During playback:
After getting back in car (you can see it picked up the same song at the bottom of the image, I selected cancel to get rid of the message):
