Headlight module cding
New to forum and need your advice please
n/s dipped headlight failed so ordered another module like for like on numbers but now light won't work at all, does it need coding and how would this be done
Man thanks in advance
Cheers Daren
I believe its full matrix led and the module I changed is 7pp941572ab dipped light
https://www.ilcats.ru/audi/?function...05&language=en
So you see there's the headlamp and then there's two electronic control modules. (2) is for the main beam / dipped beam LEDs. (3) runs all the rest of the LEDs.
Thus the question of did you replace the headlamp due to some issue with it. Or did you replace the control module due to some issue with it. A new control module has no programming; it knows nothing about how to work correctly. It'll have to be programmed. I'm sure there's threads around here or elsewhere of people attempting that on their own. VCDS won't be able to do it, VCP probably could do it if you find the necessary file, not sure if OBDeleven could attempt it. Dealership of course can do it.
Water got into module 2 causing it to flicker wih the dipped light only. Replaced module with like for like numbers believing it was plug and play but now I've no dipped nor main beam
