Help
https://www.vwvortex.com/threads/my-...grade.9206297/
If you go down to the AFTERMARKET AMP (FENDER VERSION) section, you see him discussing the problems of replacing the stock amp in an optical ring MIB2 environment. So he just used the speaker level outputs of the factory amp to feed his aftermarket config. Which you don't have the option of. But note where he discusses the amp outputs on the J794 itself. This is the situation with the standard sound system, where there is no external amp. Since you're effectively eliminating the B&O aspect of the system removing the stock B&O amp, you might as well reconfigure the J794 as standard sound system, then you can use the speaker level outputs on the J794 to feed an aftermarket system. The standard sound system has 6 amp outputs, "four corners", dash center channel, and subwoofer. So you're still stuck with the Audi crossover configuration. There's no line-level outputs in MIB2. And the B&O speaker config uses 16 channels, so you're going to need a lot of aftermarket amp to drive the system.
The stock B9.0 B&O amp comes in four versions according to the parts catalog, but no explanation of which is which or why:
8W0 035 223
8W0 035 223 A
8W0 035 223 B
8W0 035 465
You'd have to confirm which you have. But a used one of those seems a lot more direct and quick solution - https://www.ebay.com/itm/225152370440 But it'll still require a one hour labor bill at the dealership to do the 10 minute job of resetting component protection.
8W0 035 223
8W0 035 223 A
8W0 035 223 B
8W0 035 465
Thank you for your time and consideration.
Squeeze the end of the cover cap opposite the wires to lift it out and remove the cap.
Then the set of locks for the various pins depend on the pin in question.
