Lossing tire pressure on my A4
So i got a tire pressure losing warning which is a yellow indication light, and i went to Big O Tire to fix that like right away after that light shows up. They found a neil in the tire and they patched that. However the yellow warning was still there. They told me thats because i need to drive the car then the pressure measure things would catch up. But after i drive like 5 kilos to home, the yellow light is still on. What should i do?
Did you reset the tire pressure monitoring system in your MMI? With the indirect tire pressure monitoring system used by Audi, you have to notify the system when the tires are initially set to their proper pressures.
Did you check if they actually inflated the tire to the proper pressure?
Dont reset the warning in the mmi until you confirmed the pressure. Otherwise you are not going to get a warning next time you get a nail.
Do what Samuel said. First check the pressure with your own TP gauge to ensure the pressures are correct. Then you need to reset the pressure setting via your MMI. It will not reset itself.
Samuel Weir
A4 (B9 Platform) Discussion
41
12-28-2017 01:43 PM
olallaray
09-07-2017 07:43 PM
MrAngry
Audi A3 / S3 / RS 3
04-26-2006 01:45 PM
