OBD Codes!
I have a BlueDriver OBD 2 reader that I've been using on different cars every time I the engine light came on.. and lately I use it on my Audi A4 2017 Progressive.
When I bought the car I have noticed those codes (this is a crop from the phone screen-shot):
The dealer that I bought the car from, told me that the car was inspected (and provide inspection report) by VW OEM Dealer and no problems were found and probably the previous owner when returned the car from lease there was some service and they forgot to clear the codes...
I didn't know what to say so I bought the car which runs nice and smooth...
My previous mechanic told me once that some of the codes come on with different errors and not necessary with a problem, so if the engine light doesn't come on the dash but you see any error codes after a OBD2 scan - by clearing the codes and drive few days, see if they come on again .. if not, probably it wasn't a real problem but just a temporary error in the system.
Based on this statement I did clear the above codes and drove over a month and they didn't come on again... which, I guess, it is ok!
Now, yesterday I did another scan and I have noticed this new error code 522:
The engine temperature seems to be measured fine on the dash - I mean, it starts cold and in few km it gets to 90*C and stays there for the rest of the ride - which makes me think that everything works well. As I know, a short circuit may cause fire, or for this sensor to not measure the temperature at all. I was also expecting an error on the dash - for such a problem.
After I noticed this, my first taught was to clear it and wait few days to see if it will come again - but then I considered to share this here - not all mechanics might be honest and not all cars are the same.
At this point the error code still shows up when scanning with the OBD2 and car runs perfectly...
Any thoughts are appreciated
Stefan
More specific definition
Is it possible for an error to remain active - simply because the system got it once and stay there until cleared (even if the problem was real and fixed by a mechanic) ?
There are such a thing as Permanent DTCs (code) - they are relatively new and didn't exist when I last had to deep dive into codes/types/etc.
Here's a summary - https://www.autoserviceworld.com/car...ermanent-dtcs/ I don't know if a temp error would fall under emissions as a possible permanent code - possibly, due to rich fuel/increased emissions at cold start.. The article documents a Universal Drive Pattern that is supposed to clear "permanent" codes. It seems like something that would occur in the normal course of driving, but who knows.
(It wasn't clear, but if you had previous cleared this same code with a code reader then it's not a Permanent Code)
But.. WOW.. last night I did another scan and another codes pop-up:
1st: 5644: Low Fuel Pressure regulation Fuel pressure fluctuates
2nd - RKA Pressure Loss, Puncture detected - which is a list that doesn't make any sense for me since this car doesn't have pressure sensors to read the exact tire pressure - but all it does is go with the ABS wheel rpm / compared with the rest of the wheels. So not sure how it can detect a tire puncture. Also the pressure in the tires didn't change at all since mid September - when I bought the car and tested the pressure:
I don't know if this BlueDriver is the issue or the Audi - which is a German quality car - so my expectations are pretty high on it, especially for that price tag I paid.
I'll clear all those codes today and see how it goes...
https://mechanicbase.com/engine/low-...mptoms-causes/
This is one of the reasons Pending codes aren't exposed to the owner/driver/user. Modern cars are very complex, highly computerized pieces of equipment. Nothing is perfect and there are layers and layers of validation, verification, etc. You can go crazy worrying about one-off signal errors that don't exist.
Until the electronics of the car, which are designed to tell you when something is actually confirmed to be wrong, tell you there's a problem, I suggest you not try chasing ghosts.
I'm pretty sure my last few scans have turned up a pending issue or three. I never thought twice about it, and the service techs never mentioned it when in for factory service.
(Interesting trivia - when my daughter's RX350 throws a "Check AWD System" error, I tell her she forgot to tighten the gas cap. It's a well know Lexus diagnostic)
Yesterday I just cleared the latest codes, drove 20km, scan again to find out that none of them come back... and to make it clear I also sold the BlueDriver... Hahaha...
I'm looking to get the OBDeleven instead... just a bit afraid not to brick the car!
