Outside Temperature
Old Jul 25, 2017 | 08:52 AM
PPOPHIL's Avatar
Default Outside Temperature
Is there a way to adjust the outside temperature (couple of degrees +/- ) in the display?
Old Jul 25, 2017 | 09:17 AM
edle's Avatar
I don't think so. It displays based on what it reads which is how it should be.
Old Jul 25, 2017 | 09:41 AM
PPOPHIL's Avatar
Most vehicles you can adjust a few degrees up or down. Something's I feel the temperature displayed is wrong
Old Jul 25, 2017 | 01:18 PM
Dan in St. Louis's Avatar
It will certainly read higher on the road than the weather bureau says, especially over black asphalt. It will also read higher when parked after a run, since engine heat affects it.
Even the weather bureau displays different readings across the city.
Old Jul 25, 2017 | 04:14 PM
Dave788's Avatar
I had an adjustable thermostat as you mention in my Honda but never used it. My reasoning was passing through the same point and time at different speeds, I.e me parked on blacktop on the side of the road on a hot day vs. driving 80 mph down the same road, I'm going to get two different temperatures at the same point. Also, in the town I grew up in, the temp in town was always 2-3 degrees warmer than the 2 miles in the country outside of it I lived. So reported temperature always reflected the town and not the country. If you notice major discrepancies that conditions don't explain, I would bring back to the dealer. May have a faulty sensor.
a_very_naudi_guy
21
Jun 5, 2018 05:10 PM
janB7
Q5/SQ5 MKI (8R) Discussion
19
Feb 26, 2015 01:47 AM
DAGATY
10
Oct 9, 2007 08:02 PM
Pabblo
16
Apr 18, 2006 01:14 PM
gregmag
Chicago Discussion
19
Jul 26, 2005 08:27 PM
