Throttle Issues
Old Jul 20, 2024 | 06:25 PM
Eric.stammen's Avatar
Default Throttle Issues
2017 A4 runs good but randomly it will throw an error on the dashboard that says cruise control disabled and the car no longer accelerates at normal rate but still maintains speed. Have tried to pull codes but it doesn't seem to show in basic OBD scan I have done. If I push the gas pedal all the way down it doesn't seem to happen but if I light foot it during on ramp or something similar it will throw the error and the only way to clear it is to turn the car on and off.
Old Jul 21, 2024 | 12:41 PM
Error that comes up on dash is Drive System: Malfunction! no other details on it other than cruise control is disabled and the car no longer has normal acceleration
Old Jul 21, 2024 | 02:09 PM
142 guy's Avatar
Are you using a generic OBDII scanner? In general, generic scanners don't play well with VW / Audi products and almost certainly will not be ale to read the range of Audi specific error codes. You need a scanner that supports the extended VW / Audi error code set. VCDS and OBDeleven are low cost examples of VAG enabled scan tools.
Old Jul 21, 2024 | 03:32 PM
I have used the OBDEleven tool and it brings up a few other random system errors in sound system and nav but nothing to do with engine. Maybe I am looking in the wrong place for this?
Old Jul 22, 2024 | 07:20 AM
142 guy's Avatar
I am not familiar with OBDeleven; but, I would assume that it has a function that allows you to scan for all active, pending and prior error codes (that have not been cleared)? The description of the Drive System Malfunction warning light is very limited for my 2021 and doesn't really provide any useful information other than the fact that something bigger might be cooking.
Out of curiousity, does this error / problem only occur when the cruise control is active or can it occur anytime? If it can occur without the cruise control being active it might be unrelated to the cruise control and what you might be experiencing with the throttle is the car going into a limp mode. Are you getting any misfires when this is happening? Does OBDeleven allow you to monitor for DTCs in real time. You might be getting some errors that are pending; but, then clear if everything returns to normal.
Old Jul 22, 2024 | 08:44 AM
Mike60564's Avatar
Sounds similar to the earliest symptoms of the turbo wastegate shaft problem that I just fixed. At first it was only when the engine had had a good heat soak (driven to full operating temp and then off for a half hour or so) and under mild acceleration.
Old Jul 22, 2024 | 09:00 AM
LightningTruck's Avatar
The "Drive System: Malfunction!" is a completely meaningless modern version of the dashboard idiot light.
Buy a real code reader or hire a professional.
EXAMPLE:
1 Fault Found:
14846 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [096] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 16
Mileage: 124464 km
Date: 2021.10.28
Time: 15:47:17
Engine RPM: 2041.75 /min
Normed load value: 62.0 %
Vehicle speed: 37 km/h
Coolant temperature: 92 C
Intake air temperature: 12 C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.144 V
Unlearning counter according OBD: 31
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000001
Charge air pressure control valve position: actual value: 0.00 %
Charge air pressure control valve position: target value: 0.00 %
Charge air pressure control valve activation pulse duty factor: -30.34 %
STATE_BPA[0]: AD
Charge air pressure control valve uncond voltage sensor: 4.5215 V
Charge air pressure control valve voltage: position closed: 4.5056 V
Readiness: 1000 0000
Old Jul 22, 2024 | 02:36 PM
Cruise control seems to remove the problem all together if I engage it. If I accelerate with the gas pedal slowly it seems to cause the problem the most. Say I go from a stop to 55mph if I press the pedal to the floor its fine if I give it about 75% throttle you can almost feel it in the car not accelerating at full speed and then it trips the error and disables the use of cruise control all together. Was leaning towards a accelerator/throttle body issue since it only happens with the gas pedal controls and not cruise control operation.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 22, 2024 | 02:37 PM
I can replicate the issue from a short drive to long without any real difference between the two from what I can tell. I did have the waste gate issue and did the adjustments I could and got that error to go away all together its been two years at least on that.
Old Jul 22, 2024 | 03:15 PM
142 guy's Avatar
On the basis of limited evidence I expect that you might have a return of your waste gate problem and that cruise control on or off has nothing to do with the root cause. Having the cruise on might just be masking the symptoms. Have you checked to see if your waste gate has become loose?
OBDeleven should have been able to pick up a P2563 DTC.
