Aggressive wheel offset ?
Old Apr 24, 2014 | 06:14 PM
cbnat's Avatar
Default Aggressive wheel offset ?
I have a 2012 A6 with the stock 18x8 ET 39 wheels. I am looking at a set of 20x9.5 ET 35 wheels. According to the 1010 calculator I will lose 15mm inner clearance and push out 23mm toward the fender. That's almost a full (.905) inch out.
Anyone know if this will fit and if it does what about with springs? I have eibach pros in the box to go on when the wheels do. Unfortunately, this isn't a situation where I can test fit the wheels because they are located in another state.
Thanks!
Old May 7, 2014 | 04:07 PM
r1racer's Avatar
I have 20x9.5 ET 39 with the sport springs...not sure if this helps but if I dropped another half inch I wouldn't rub.
Old May 7, 2014 | 05:34 PM
jr'sAudiA6's Avatar
Thanks!
For my track set-up I have the A7 wheels, 20x9 ET 37 with 275/35 20 tires. The car sits pretty low about 26.5 inches from ground to rear fender. This set-up did rub the inner lining a little until I cut a small portion out. So for what you are trying the wheels should not cause any problems so long as you are using stock tire size. I put your data into this web page http://www.rimsntires.com/specspro.jsp and it indicated no problems, again using stock tire size.
Old May 9, 2014 | 09:08 AM
Hockenheim's Avatar
pics of setup please,
Old May 9, 2014 | 03:22 PM
jr'sAudiA6's Avatar
Here are some pictures of my track setup.
Old Mar 4, 2018 | 08:06 AM
Luca Fagundes's Avatar
I just purchased those exact A7 wheels, 20 x 9. I have a '14 A6 Quattro, 3.0, that came stock with 18's. The 20" wheels should be here in a couple days, and purchasing tires at a local Discount Tire. Discount tire recommended 275/35/R20. Seems that's the stock tire for the A6, but not sure it will fit my car.
You mentioned that you had to cut the lining a bit, as you were getting some rubbing? Where and how much did you have to cut?
If I have rubbing, at least Discount Tire will simply order something else, i.e. I won't be on the hook for the 275's. But seems you made it work???
Also, did you have to re-set computer at all given change in wheel/tire diameter?
Old Mar 5, 2018 | 01:38 PM
jr'sAudiA6's Avatar
I stopped using the 275/35/20 tires because of the rubbing both front and rear. I had this rubbing most likely because of my lowered suspension. The stock tire size is not the 275 but the 255/35/20 size. The other part of the rubbing equation is the offset for the A7 wheels is 37mm vs, 45mm for the stock 20 inch wheels.
Old Aug 2, 2018 | 03:14 PM
This is how mine turned out. Very happy with them.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 3, 2018 | 03:10 PM
DanfZX14's Avatar
VERY sharp ride!
Old Aug 4, 2018 | 11:31 AM
DB22's Avatar
If anyone is looking for a set of 20’s as shown in jr’sAudiA6 original setup PM me.
