Audi Smartphone Interface
Old Oct 16, 2016 | 04:02 AM
RafAudi's Avatar
Default Audi Smartphone Interface
Hi,
I've been trying to activate the Audi Smartphone Interface (ASI) on my 2017 A6 Avant.
So far i've managed to enable the relevant menus (see screenshots below) by using the adaptation in module 5F with VCDS but now i'm stuck.
The ASI initializes, but after that the connection manager just shows a blank screen. Does anyone have an idea how i can get this to work ?
Attached Thumbnails Audi Smartphone Interface-p_20161015_130921.jpg   Audi Smartphone Interface-p_20161015_125725.jpg   Audi Smartphone Interface-p_20161016_132141.jpg
Old Oct 16, 2016 | 01:43 PM
HiTEC's Avatar
Your supposed to be able to plugin your Apple iPhone or Android phone (with Android Auto installed on) and it should start right up.
Old Oct 17, 2016 | 11:08 PM
RafAudi's Avatar
My car did not come with the option activated from factory.
This is what i've already adapted to enable the menus:
Address 5F,4G1 035 043 F,channel IDE03471-ENG130248-Vehicle configuration-Google_GAL,adapted from,OFF ,to,On ,Saturday,15,October,2016,12:37:58:49450
Address 5F,4G1 035 043 F,channel IDE03471-ENG130249-Vehicle configuration-Apple_DIO,adapted from,OFF ,to,On ,Saturday,15,October,2016,12:39:13:49450
Address 5F,4G1 035 043 F,channel IDE03471-ENG07590-Vehicle configuration-Mirror_link,adapted from,OFF ,to,On ,Saturday,15,October,2016,19:46:09:49450
Address 5F,4G1 035 043 F,channel ENG107658-ENG126193-mobile phone voice control availability-other_devices,adapted from,not installed ,to,installed ,Saturday,15,October,2016,13:04:09:49450
Address 5F,4G1 035 043 F,channel ENG107658-ENG126192-mobile phone voice control availability-apple_device,adapted from,not installed ,to,installed ,Saturday,15,October,2016,13:15:35:49450
I've read that an activation file could be required to activate the connection manager, does anyone know more about this ?
Old Nov 6, 2016 | 07:34 AM
JCPenochet's Avatar
Bonjour,
J'ai le même problème que vous sur une audi TT 2017 que j'ai fait la bêtise d'acheter sans l'Audi Smartphone Interface.
Par contre j'ai l'option phonebox, donc l'iphone est relié par cable.
Quel système VCDS utilisez-vous ? Peut-on modifier les codes ?
Pensez-vous que le concessionnaire puisse le faire ?
Merci de votre éclairage
Old Nov 6, 2016 | 08:45 AM
Nakedhoof's Avatar
If you didn't pay for it, you're probably out of luck. There's probably a module that needs to be installed for it to work.
Si vous ne payez pas pour cela, vous êtes probablement hors de la chance. Il y a probablement un module qui doit être installé pour que cela fonctionne.
Old Nov 6, 2016 | 09:34 PM
RafAudi's Avatar
Originally Posted by JCPenochet
Bonjour,
I'm guessing that it should become available from the audi dealers in a while (months, years, ...), as for the volkswagen and skoda versions of the MIB2 computer this has already become an official accessory that you can buy in the form of an SD card with a single use activation code on it.
However, i know for a fact that other people have found a way to enable the function themselves.
Old Jul 9, 2017 | 06:55 AM
jasell's Avatar
Any news on this?
Where you able to get the Carplay to work?
Old Aug 6, 2017 | 10:11 PM
braincell38's Avatar
Has anyone figured out how to activate ASI via VCDS? I'd really like to have carplay work on my MIB2 system.
Old Sep 3, 2018 | 09:18 AM
Cari's Avatar
Bit late to the party, but you can order ASI retrofit from the dealer: https://shops.audi.com/en_GB/web/zubehoer/p/retrofit-solution-for-the-audi-smartphone-interface-4m0051472-9 and have it enabled by the dealer. Cost me 30€ to have it enabled and 320 for the codes. Expensive, but works. https://photos.app.goo.gl/V6VnEzz1GsumDvTi7
Old Dec 16, 2019 | 10:43 AM
Antonio Affonseca's Avatar
Hello,
Was there any hardware update or only software? Did you do it yourself?
I have the Audi TT 2015/2016, it has the USB ports with the screen icon, but it does not show the ASI icon ever!
