Auxiliary Heating
[08 - Auto HVAC]
[Adaptation - 10] -> Channel 6 change 0 to 1
My screen is different, instead of allowing me to select channel 6, i have a drop down menu with a bunch of features description.
Could it be that or additional hardware is needed?
The Auxiliary heater (9M9) is an Eberspächer (used to be Websto I think) system that burns diesel to create heat. It's controlled either by the extra remote or by MMI. If you don't have the extra heater nothing will happen except you might start the fans and circulate the air.
The Auxiliary Heater option is like $2320 here in Sweden.
If you dont buy the Auxiliary Heater when buying a TDI an electrical heater is installed from factory. This heater cannot be used with a timer, its simply a way of getting heat into the compartment when starting a cold car which would take ages on a diesel.
If I am leaving the car in hot (or cold) outside temps and simply would like to take advantage to circulate the cool (or warm) air remaining, I can do this:
1. Turn off engine
2. Press and hold the left fan button for a few seconds until the preset temp readouts appear
3. Release fan button
4. Wait for a few seconds; the climate fans will then come on and will push cool or warm air through the vents
5. Eventually, the fans will automatically turn off.
Note that this can only work effectively so long as the air temp in the system is cooler (or warmer) than the car's interior. Evetually it's just circulating the temp of the air in and out of the car.
I'm not entirely sure how long the fan(s) run or if it has anything to do with the ambient temp remaining in the system vs. the ambient temp in the car's interior or if it's simply on a timer. I know that I've been gone for 10-15 minutes or so and they were still running.
1. Turn off engine
