Dynamic mode
Old Jun 10, 2012 | 01:19 PM
dht34's Avatar
Default Dynamic mode
When the car is set to Dynamic, is that the same Sports mode? Much like the Sports gear in the A4. Noticed when the car was switched to Dynamic, a letter 'S' lit up on the dash. When back in Comfort, went back to 'D'
Old Jun 10, 2012 | 02:47 PM
Metallic-Force's Avatar
The S comes from the gear shift, you shift it back to get to "S" at least that's in my car. The dynamic mode changes the steering mostly.
Old Jun 10, 2012 | 02:49 PM
joseaudi's Avatar
dynamic setting will also affect the stearing feel and response. in europe it would affect the shock stiffness as well. Sport is just higher revving gear changes.
Old Jun 10, 2012 | 03:35 PM
dht34's Avatar
I see. Thanks for the clarification.
Old Jun 10, 2012 | 04:07 PM
YHan01's Avatar
I think it also affects the throttle response.
Old Jun 10, 2012 | 06:05 PM
snagitseven's Avatar
Super Moderator
The only difference in the A6/C7 with the Dynamic setting vs. Sport Mode is the steering feel. Both modes affect throttle and transmission mapping. In other Audis with ADS, Dynamic setting also affects suspension.
Old Jun 12, 2012 | 07:46 AM
awryexperiment's Avatar
I can see how the "S" indicator for "Dynamic Mode" and the "D" indicator for "Comfort mode" is confusing.....
Old Jun 12, 2012 | 09:11 AM
manishaudi's Avatar
"S" & "D" do not indicate Dynamic or Comfort Mode - They indicate your transmission selection
Well, for all modes "D" is just 'drive'.
When you are in Dynamic mode it switches to "D>S" for 'sport drive'. If you tap the GearSelector down and change to "D" it will take you out of Dynamic mode
in Comfort & Auto modes if you tap the GearSelector down when you are in "D", you can enable the "D>S" sport drive for those modes. Tapping it down again reverts you back to "D".
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 12, 2012 | 11:17 AM
dht34's Avatar
Now I understand!
So there is no need to even activate the Dynamic mode throught the MMI, just gear select down is sufficient for both Dynamic and Comfort modes.
Old Jun 12, 2012 | 12:32 PM
Super Moderator
Originally Posted by dht34
Now I understand!
Unless you also want to tighten up the steering...
q5q7
A6 (C7 Platform) Discussion
28
Feb 10, 2014 09:57 PM
The G Man
19
May 20, 2012 06:12 PM
boybike
9
May 27, 2007 10:13 PM
Tom1996
Jan 2, 2005 08:28 AM
guddn17
Nov 8, 2002 05:49 AM
