Engine block plug
Old Mar 3, 2026 | 06:37 AM
Capt. Al's Avatar
Default Engine block plug
Hello all. Trying to finish a head swap on my wife’s 2012 A6 Quattro 3.0T. After removing the crankshaft lock pin, I discovered my plug is missing. After spending several mornings and a couple evenings searching for it, I decided to toss in the towel and just order another one. This endeavor is proving to be every bit as challenging as searching for the lost one. My question for this topic; does anyone know the proper name of this plug? Part number? Vendor?
Thanks Guys
Old Mar 3, 2026 | 09:28 PM
Sallad's Avatar
Veteran: Canadian Forces
Community Builder
ECS sells them
Locking Pin Cover Bolt
Old Mar 4, 2026 | 04:39 AM
Valpo A7's Avatar
You will find the old once you order the new. That is how home mechanic life rolls. Check the locking kit box to see if you tossed it there for safe keeping.
Old Mar 4, 2026 | 10:19 AM
Capt. Al's Avatar
Thanks Sallad. I might do that. Rather expensive for a plug, especially with 36 dollars shipping.
Good advice Valpo. Not in there either though. Just finished bolting in the heat shields on that side. I think those were the worst part of the job so far. 😩
Old Mar 4, 2026 | 10:23 AM
Sallad's Avatar
Community Builder
Yup... that's why I have four 10mm sockets, a few 13mm sockets. I think I loose them, go buy a new one, day later find the lost one. haha
As for sealing the hole, any junkyards near you? I'm sure any VW or Audi would have one that fits. Or even a short bolt with the same thread pitch as the hole, put a small O Ring or crush washer on the bolt and be done. Its only a sealing plug, nothing structural, just needs to hold back splashes of oil, no real pressures.
Old Mar 4, 2026 | 10:37 AM
Capt. Al's Avatar
Disregard what I said about the shipping. I see the shipping is free. I had ECS TUNING confused with a different website.
Anyway, thanks again for the heads up. I ordered that one so by the time I get radiator and front end back together, that final detail should come sliding in and I’ll change oil and top off the coolant.
As an aside, the reason for doing this job is due to a bad misfire on 6. My own diagnosis led me to suspect a burnt valve.
Diogo3008
May 6, 2022 10:47 AM
Pete E
Jun 26, 2016 07:06 PM
spydox
Apr 17, 2013 12:07 PM
CURSH
Jan 25, 2005 06:43 AM
+pressure
Apr 24, 2003 03:24 PM
