Engine Oil Recommendation
I was wondering if anyone has had any experience with this specific oil ....? Or if anyone can recommend a better one.
I was also looking at Mobil 1 Extended Performance. Any help will be appreciated. Thank you
You'll need to use an oil meeting VAG quality standard 502.00 if you wish to comply with warranty requirements for the USA. It's that simple.
Welcome aboard, Archie!
They still seem to prefer 5W40 oils vs. xW30 oil. Keep in mind that the 502.00 spec contains minimum "thickness" guidelines so the end consumer technically does not need to be concerned with the weight of the oil cuz the spec takes care of that. Example: Castrol 0W30 meets the 502.00 spec and therefore MUST comply with the minimum thickness guideline.
I don't think there are any 5W30 502.00 oils sold in the USA at retail. (Pennzoil offers something but it may be bulk-supply only.)
I'd say the "common" 502.00 oils are M1 0W40 and Castrol 5W40. Many Autozones have the Castrol 0W30, too.
https://www.audiworld.com/forums/sho....php?t=2802944
