Gauge Sweep From 4K
Old 04-22-2014, 06:55 AM
DB22's Avatar
Default Gauge Sweep From 4K
I have enabled gauge sweep but the tach only sweeps from 4k to max.
Would anybody confirm that this is normal/typical or is there something that I'm missing?
Thank you.
Old 04-22-2014, 07:52 AM
fEArmE's Avatar
Thank you.
Don't quite understand how it starts from 4k. Can you post a video? Mine starts from 0 to 8 then back to 0. Same goes to the speedometer.
Old 04-22-2014, 07:54 AM
DB22's Avatar
No red LEDs from 0 to 4K but sweeps from 4K to max and then back to 0.
Old 04-22-2014, 09:48 AM
jdong's Avatar
Umm… The "gauge" sweep primarily refers to the needle going through from minimum to maximum before coming back down.
The red LEDs are the redline indicator, and for a cold TDI is as low as 4k RPM. There are no LEDs below 4000. That's how it's supposed to be.
Old 04-22-2014, 05:45 PM
fEArmE's Avatar
ok.. that's normal. Mine does the same thing. Red LED from 4k to 8k.
Old 04-23-2014, 03:09 AM
DB22's Avatar
Thank you all for the confirmation.
2001S4ICS
08-04-2007 12:47 PM
blackfnTTruck
02-06-2006 03:46 PM
QuattroRocket
01-12-2006 03:25 PM
t0mt0m
10-22-2004 03:52 PM
homeslice
10-31-2003 08:37 AM
Quick Reply: Gauge Sweep From 4K
