Paint Code?
VIN: WAUFGAFC2GN114122
Picture of car?
What color do you think it is?
Also if the option sheet is not in the spare tire well, maybe someone removed it and put it in the glove box?
https://monroney.manheim.com//pdf/WA...905414?lang=en
https://www.hstuning.com/audi-paint-...-metallic.html
https://www.getaudiparts.com/oem-par...kgUGFnZQ%3D%3D
Unfortunately or fortunately, depending on how you look at it, they are usually a two part kit with the clear separate. Since you are having a pro do it might not be an issue. I just find the two part can be difficult if you are not a pro, they will probably just build up and then polish down any bumps....which might work better...
I prefer Dr. Colorchip for a DIY project...No clear...not for large chips, and only really minimizes the appearance, doesn't eliminate altogether. Still, it worked well for me.
https://www.drcolorchip.com/
just saying... if the chips are big, clustered, or barely noticeable maybe let it be.
