Performance of the A6 with the 2.0T engine
Old May 19, 2013 | 09:11 AM
  #11
qqq1970's Avatar
Dumb question. Would gas mileage improve if I put full load tire pressure vs. half load tire pressure?
Old May 19, 2013 | 09:42 AM
  #12
DeerHunter's Avatar
Yes, due to reduced rolling resistance.
Old May 19, 2013 | 11:15 AM
  #13
fEArmE's Avatar
Yep... I have 38 psi front and 41 psi rear. Some ppl may not like it due to higher pressure giving them harsher ride or less comfy.
Old May 19, 2013 | 11:22 AM
  #14
Mickelin's Avatar
And more road noise!
Old May 19, 2013 | 12:21 PM
  #15
snagitseven's Avatar
Super Moderator
Maybe 1 or 2 mpg but not much more. (I've tried it over a period of time on several cars).
Old May 19, 2013 | 12:24 PM
  #16
Super Moderator
Originally Posted by rmorin1249
On a level road at 65 mph, I can easily get 32 - 34 mpg.
For a 2.0t that makes sense. Not gonna quite get there on a 3.0 though.
Old May 19, 2013 | 01:05 PM
  #17
tenspeed's Avatar
Mythbusters had a test where they started with a car that had a normal tire pressure of 35 psi.
30 psi = 1.2% increase in fuel use
35 psi was base line
40 psi = 6.2% decrease in fuel use
60 psi = 7.6% decrease in fuel use
If you want better MPG's, a little is good. A lot doesn't make it a lot better.
Old May 19, 2013 | 03:35 PM
  #18
qqq1970's Avatar
Thanks. Full load tire pressure then.
Old May 20, 2013 | 05:09 AM
  #19
qqq1970's Avatar
Right now 39/36. Looks like if I go to 44/46 full load mileage improves by 6.2%.
Old May 20, 2013 | 09:39 AM
  #20
tenspeed's Avatar
I use www.fuelly.com to keep track of my MPG's. You can note any changes that you make.
