A6 (C8 Platform) Discussion Discussion forum for the C8 Audi A6 produced from 2018
Coolant loss
Old Feb 11, 2023 | 01:18 AM
fishphone's Avatar
Default Coolant loss
Definite slow coolant loss 2019 40TDI 48k miles. No visible signs of an actual leak. Checked oil filler cap, normal. Is this a common issue? Been advised not to put any of the propietory radiator sealant liquids in. Car still under extended warranty, would this be covered please. Any help appreciated
Old Feb 11, 2023 | 02:17 AM
John Simcox's Avatar
25 Year Member
Doesn't sound normal. Definitely do not add any sealant and also only use the correct rated antifreeze mixture to top the tank up. Most likely cause is a faulty cap and changing that would the easiest cheapest option. Alternatively you will probably need a pressure test to see if there is a leak. Could be a tiny hole in the radiator caused by a stone. Alternatively it could be the water pump leaking, a pipe that has a small hole or a simply has come loose. As I say a pressure test will give you the answer. As to being covered by warranty, I guess it will depend if it is found to be caused by (stone) damage, general wear and tear or failure of item expected to last. I suspect that only in the last case will it be covered by warranty..
Old Feb 11, 2023 | 02:38 AM
fishphone's Avatar
Thank you very much John for a comprehensive and rapid reply.
Old Feb 22, 2023 | 01:07 AM
fishphone's Avatar
Confirmed water pump. Covered under warranty
Old Feb 22, 2023 | 02:27 AM
25 Year Member
Glad it is sorted. Did they replace the thing belt at the same time?
stevefoster
A4 (B9 Platform) Discussion
Aug 1, 2022 03:23 PM
SkiBum2
1.8T Discussion
Jan 23, 2011 05:39 PM
SPC425
Dec 31, 2004 02:45 PM
S4carl
Jan 23, 2003 01:40 PM
jjm
Sep 4, 2001 12:57 PM
