Oil leak suddenly got real bad....help
Old 01-07-2013, 04:03 PM
sabresfan's Avatar
Default Oil leak suddenly got real bad....help
So I have been chasing an oil leak on my 2.8L for a while. I re-did the VC gaskets, no luck so I bought a kit on Blauparts because the places where oil was dripping was consistent with the CCT seals/plugs. I have been waiting for a chance to do it since the leak hasn't been too bad. Maybe a quart every 3 weeks or so. I just checked the oil the other day and it still was ok. All of a sudden today I noticed a huge puddle under the car. It is dripping noticeably right down the center of the oil pan and was down 3+quarts. Something else must have popped. At this point I am resigned to putting her in the service position and replacing everything. Anyone have any idea why the leak got real bad all of a sudden? Is visible leaking down the center of the oil pan indicative of something? I am not a mechanic (obviously) but here are the places I can think if where oil is possible coming from:
VC
camshaft seals
crankshaft seals
CCT seals
CCT plugs (half moon)
oil pan
Am I missing anywhere else obvious, or maybe not that obvious?
any help would be greatly appreciated.
Old 01-07-2013, 04:29 PM
Tech Guru
4Driver4's Avatar
Before you tear it all apart, check the oil cooler o-ring.
Old 01-07-2013, 06:18 PM
GTA_Driver's Avatar
Another thing, check the PCv valve, it could be clogged. What mileage?
Old 01-07-2013, 06:34 PM
sabresfan's Avatar
Thank for the reply guys. It has 110K. I filled it with oil, cleaned the bottom and ran it. It immediately started leaking BAD from what looks like the front crank seal. It was just flowing down right down the middle of the oil pan. Could it be anything else?
Old 01-07-2013, 08:10 PM
autlaw's Avatar
Old 01-08-2013, 04:57 AM
sabresfan's Avatar
Mine is a 2000 A6 so I am not sure if that is applicable. This leak is bad.....probably too bad for a sensor of any kind
Old 01-08-2013, 07:19 PM
mike101's Avatar
Had that problem last month. In my case was crankshaft seal. If that's the case remember to buy new crankshaft bolt along with the seal. You will also need crankshaft lock pin, and a cam lock bar.
helldriver71
01-14-2012 03:06 PM
audirunner
03-24-2004 02:18 PM
Rick 601
Audi 100 / A6 (C4 Platform)
02-19-2004 12:36 PM
Audi-Loyal
04-06-2002 06:10 PM
S4 JJ
01-14-2000 01:38 PM
Quick Reply: Oil leak suddenly got real bad....help
