2000 2.7T continues to run hot
So you are saying that after the coolant temp sensor change the engine runs hotter?
Electric fans are running after stopped because coolant temp is high. They are automatic and will run as long as necessary to cool down the coolant.
The engine driven fan should not be easily stopped when the radiator is warm. The fan should engage when the radiator/coolant temp rises. You can even hear it whir if you rev the engine slightly.
Upper hose hot ant lower hose cold could be a partially opening thermostat or perhaps a partially clogged radiator ( do not overlook this possibility)
The coolant bottle was badly cracked, but had no fluid leaks that I (or the shop) could detect. The secondary water pump, however, was leaking; I had the pump replaced. To be safe, I also had a coolant flush (which, per VW stupidity, had never been done in the 96k mile life of the car) and had the bottle replaced. As an added precaution, I mixed in some water wetter. Ever since, I haven't had any problems. But I haven't really been on any drives that intense since the work was done.
So, my suggestions are as follows:
1.) Check the secondary water pump for leaks.
2.) Ensure the coolant is fresh.
3.) If the bottle is cracked, get it replaced (as suggested above).
