low speed wobble
Old 09-19-2018, 06:49 PM
Osmosis's Avatar
Default low speed wobble
I've no idea of what is wrong with my A6 2.7t. I rebuilt the engine 2 years ago along with new CV joints. I recently developed a low speed wobble at aprox 20 mph. Between 15-25 is very noticable. When I get past 30, the wobble is barely noticable.
I checked my wheel hubs for play...no play. I checked my CV shafts for play and I had some up and down and rotational play on my drivers side whereas I had no play on the passengers side. I replaced my drivers side CV joint suspecting that that was the problem.....NOT
This started about 2 weeks ago from nothing to hello, I'm here to F with you. Pisses me off!
I've no idea of what to look for next, any help would be greatly appreciated!
Old 09-20-2018, 04:08 AM
johnkk's Avatar
try moving wheels to different positions to see if the wobble changes. Might be bad tire or bent wheel. Another idea: get all 4 corners in air and start car to get wheels spinning slowly to look for wobble.
Old 09-20-2018, 04:17 AM
georgeb944's Avatar
It might be a bad tire. Jack up the car so all the tires are about half an inch off the ground. Rotate each wheel slowly, and look for a change in the gap between the ground and the tire. Usually an indication of a belt inside the tire that has come loose.
Old 09-20-2018, 09:28 AM
Osmosis's Avatar
I've rotated my tires with no change. I have noticed that my tires in the rear are worn on the inside corners. I am at the tire wear indicator tread marks and it could be tires. The thing that puzzles me is that it started like a switch. One day, the shake appeared out of no where? The car seems to rock from left to right?
Old 09-20-2018, 10:49 AM
georgeb944's Avatar
Find another set of wheels and tires to swap onto your car temporarily. Ninety percent probability that it is wheels and/or tires.
Old 09-20-2018, 02:45 PM
Harleyguy's Avatar
Sounds very much like a broken or slipped belt internal in the tire. Maybe more than one tire especially if they are all around the same age. How old are the tires? It would be easier to observe at a tire shop with the wheel/tire on the dynamic balancer. It would show up as a lump or maybe a wiggle in the tread when you spin the wheel by hand. Also the tire would be unbalanced. With the tire wear you described, how do the rubber bushings look in the suspension components? Trying to hit all the bases here.
Old 09-22-2018, 09:02 AM
Osmosis's Avatar
I'm kind of coming to the conclusion that it is tires. I have nice Michelin tires on it but they are worn to the wear indicator marks. Time for some new tires as of next week. Will keep ya posted and TY for the replies
vunu
04-19-2010 09:21 AM
gtrucinski
07-31-2005 08:18 AM
Bryan Slowgaro
07-23-2003 10:30 PM
Quick Reply: low speed wobble
