2003 A6 2.7T auto - ABS code - Brake Pressure Sensor 1 (G201)
01435 - Brake Pressure Sensor 1 (G201)
57-10 - Electric Circuit Failure - Intermittent
Where is the G201 pressure sensor located?
To source the sensor:
Part name?
Part number?
Maybe good source?
Want this done soon.
Thanks.
The point is that this failure is common and it's internal to the ABS electronic box that is mounted with six torx screws to the side of your ABS hydraulic pump and valve unit that is in your engine compartment near the brake booster.
www.autoecu.com
lifetime warranty.
Where is the sensor located?
What VAGcom block shows the read out of the sensor?
Could also swap a sensor over from another 2.7T I have (2002 Allroad).
Need to first rule out that it is NOT the sensor (and more likely the module).
torqued to 20NM.
8e0907597 is one p/n.
