2004 A6 4.2 ESP ABS Lights, Many Codes
I copied the codes thrown below, but can't seem to draw a conclusion as to the source of the issue... maybe you guys can?
Thanks again so much...
Friday,10,July,2009,21:03:00:32608
VCDS Version: Release 805.4
Data version: 20090602
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WAUML64B34N053529
Address 01: Engine Labels: None
Part No: 4D0 907 560 CT
Component: 4.2L V8/5V G 0010
Coding: 07752
Shop #: WSC 02334
WAUML64B34N053529 AUZ7Z0C2479353
3 Faults Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FG
Component: AG5 01L 4.2l5V USA 1014
Coding: 01002
Shop #: WSC 02334
2 Faults Found:
17087 - Brake Switch (F): Electrical Malfunction
P0703 - 35-00 - -
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 H
Component: ABS/ESP allrad 3428
Coding: 06397
Shop #: WSC 02334
2 Faults Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 14925
Shop #: WSC 08353
2 Faults Found:
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01561 - Left Rear Door
59-00 - Can't Unlock
End ---------------------------------------------------------------------
Based on my searches I have concluded that either my ABS module is shot and I need to spend anywhere from $200-$1000 to fix, or perhaps my brake light switch is broke and for $25 I can do it myself.
So my question is, do you think with the symptoms my car shows, do you think it could be the brake light switch? If so, is there a write up on how to change it? I do not know the inside workings of my car that well, but people make it sound like an easy DIY job. Sorry for not having codes yet, I am working on meeting a member locally who has a vac com so I can get those.
Thanks,
I'm curious if anyone has resolved the issue. I'm pulling codes tonight to see if anything shows up. My guess is ABS sensor.
All transmission hesitancy has gone away, performance is fantastic again and codes have cleaned up.
Rushed to Audi dealer to grab the switch $12.55 (incl tax)and search online re DIY replacement and found VW Passat was in recall of this so dealer can fix it for free. How come Audi was not recalled?
The new repalcement is in a little different shape than the original one. To describe it should be "meaty"
You can find the replacement instructions on the Passat
http://ww2.justanswer.com/uploads/de...all_Notice.pdf
Except my 2002 under dash panel are secured by 5 bolts. 2 at bottom, 3 in top part. You can find the info here (68-7).
Another small difference is A6's sitting position is 4 pin connector is at lower portion, not the upper portion as the passat one idicates.
I followed the instructions exact that came with the switch - namely, to NOT press the pedal while installing, but to carefully put it in place without pressing or pulling the brake pedal. Are the instructions wrong? I was afraid to deviate for fear of making things worse by locking things up.
Any insight is greatly appreciated!
