4.2 Changeover Valve Part Number Question
Am I correct that if I just need the arm that I'm better off going for the Gruven replacement?
In the process of diagnosing this problem, I discovered that the valve itself is difficult to move back and forth by hand, even if the spring is removed from the mechanism. But when I unbolted the valve from the block and slide it out about an inch and then moved it by hand, it was much easier to manipulate. Thoughts?
Take the whole control system apart (don't bother disassembling the intake mani), clean and lubricate everything, put the broken rod back together with epoxy and paperclips, and assemble it carefully. Refer to the writeup link in my sig if anything is unclear.
Am I correct that the shaft-end bolt is an Allen head but that the two bolts holding the shaft seal housing parts, etc. are Torx?
How did you get those wide pics -- did you have the radiator out?
