A6 4.2 owners, I went ahead and ordered up some aluminum Oil Cooler Pipes.
#22
#24
I am habing timing belt service soon. Is this an appropriate time to correct this oil cooler pipe or is it a completely different effort. If it is separate should it be done when you notice failure or done ahead of time? any opinions? thanks!
#25
#27
aluminum pipe
hey needed a pipe please email alx517@gmail.com with payment info... It fits 2001 audi a6 4.2 ?
#28
Back then I had my T-belt procedure performed, and the oil cooler pipe started leaking on me about 2 weeks later. Apparently the pressurization performed after replacing the coolant was just enough to push those brittle little pieces in the oil cooler pipe over the edge. It's a fairly common issue with the 4.2 V8's (I came too learn a bit too late).
Long story short; I ended up having to pay another $800 to have this fixed just a few mere weeks after they had the whole front end out for the timing belt.
Therefore, if I were you, I'd just replace it during the T-belt procedure as a safety precaution.
#30
Google Bufkin Engineering...
