ABS is bad, but no wheel sensor?
I have a 1999 Audi A6 Avant 2.8. The abs and brake lights on the dash are flashing, and a tech said the ABS module would need to be replaced. I did a ton of research on this forum, including the comprehensive DIY (THANKS!!), and was able to remove the unit in about 15 minutes. While I had the wheel off, I quickly looked to see if the wheel sensor was clean, and I noticed I don't even have a wheel sensor! There is a hole there where it should be, but no sensor, wires, etc....
Is it possible the ABS is ok, but the sensor somehow was removed? Can I have ABS without a drivers side wheel sensor?
Thanks for any input all. This forum is an invaluable resource!
Best,
Bill
When the units fail, they cannot be contacted, so it is quite possible that the unit is bad and there are other issues that cannot yet be accurately diagnosed because of the bad unit.
If the tech gave that diagnosis without any basic troubleshooting,I'd reinstall the controller and try to pull some codes.
I would love to just know that I don't have big parts of this car missing completely... lol
Thanks for your help man.
Bill
Often times a bad control unit won't communicate at all.
I am going to go ahead and buy a reman unit, and go from there. I've got my old one here and looks like this EBAY item will do the trick (same numbers and all) for just $60.... (seems WAY too cheap, but lifetime warranty...).
One last question: Once I put this reman unit in, do I need someone with vag-com to clear anything, or just plug and play?
Really, thank you very much!
Best,
Bill
