ABS & ESP light on??
car feels hesitant at times need to press gas down more to accelerate, won't be able to bring to shop for few days, is this gonna be a major issue?
any ideas?
thx
Good luck!
The OP said his car is running rough, and the ESP/ABS lights are on. That points to the MAF not reading correctly. This could be a result of an air leak, or a faulty mass air flow sensor. Perhaps understand how the subsystems work together before correcting someone that knows more than you.
All you have to do is google audi+maf+esp, you'll get 1000's of results. This is a VERY common problem (I can use caps and act condescending too!)
"Perhaps understand how the subsystems work together before correcting someone that knows more than you."
I like how you assume you're the only one who works with mapping ECUs.
I'm not naysaying anyone who says the MAF is the problem, YMMV.
The hesitation is probably something else, like a vacuum leak...epidemic on many cars. Find it.
Lastly, I had a hesitation that came and went for quite a long time...turned out to be a weak/failing knock sensor on an 02S6 4.2. There are two of them under the intake manifold on the 4.2 and I replaced both. End of that problem...waiting for the next....
It's worth noting this hostility is a direct result of you trying to show me up with your capital letters and condescending message. Had you asked if I was sure, or been civil, you'd have gotten a very respectful reply. But alas, this is the internet, and everyone knows everything. I'm done taking shots at you. If you'd like some light reading I have a several 1000 page german technical document that outlines motronic quite well. Just ask, and I'll link you.
Anyway. Had the ABS light come on without a change in running, I'd have agreed it was an ABS issue. The combination of the three symptoms leads me to conclude there's maf involvement. This may not be the case, but it's a good place to start.
I have the same documentation, never bothered going through it. Although what I have is more in the dozens of pages, so if you have more, that would be nice.
As for my hostility, you are right, that was uncalled for. Apologies
