Abs Peoblems
VCDS-Lite Version: Release 1.0
Saturday, 06 November 2010, 10:39:09:41874
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,06,08,15,16,17,18,34,35,36,37,45,55,56,57 ,65,67,75,76,77
Address 01: Engine Labels: 078-907-551-ACK.LBL
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D02
Coding: 06251
Shop #: WSC 12345
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 4B0 927 156 G
Component: AG5 01V 2.8l5V USA 8509
Coding: 00010
Shop #: WSC 12345
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.LBL
Controller: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00021
Shop #: WSC 05314
3 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
30-00 - Open or Short to Plus
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-00 - -
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 35-00 - -
Address 08: Auto HVAC Labels: 8E0-614-111-ASR.LBL
Controller: 4B0 820 043 G
Component: A6-Klimavolla
Note: Excessive Comm Errors
Address 15: Airbags Labels: 4B0-959-655-AI7.LBL
Controller: 4B0 959 655 K
Component: Airbag 7 Audi 0501
Coding: 00206
Shop #: WSC 02324
Address 17: Instruments Labels: 4B0-919-xxx-17.LBL
Controller: 4B0 919 930 RX
Component: C5-KOMBIINSTR. VDO D19
Coding: 05262
Shop #: WSC 05146
Address 35: Centr. Locks Labels: 4B0-962-258.LBL
Controller: 4B0 962 258 C
Component: Central Lock/Alarm D30
Coding: 15985
Shop #: WSC 12345
3 Faults Found:
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Controller: 4B0 959 760 A
Component: Sitzmemory D05
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D001
Coding: 00006
Shop #: WSC 12345
1 Fault Found:
01539 - Headlights Not Adjusted
35-00 - -
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Controller: 4B0 035 186 A
Component: Radio D02
Coding: 00117
Shop #: WSC 02325
End --------------------------------------------------------------------------------------------------
any one ever see those abs codes before?
Check this ABS Wizard out
http://www.modulemaster.com/en/wizard/index.php
Repair, remanufactured on ABS module service is considered to be much cheaper.
"Component: ABS/ASR 5.3 FRONT D00"
where it says front should say Quattro , I had the same issue,
you can't change coding on those at all
I shipped to get repaired and they send me someone else module and it was for Front Wheel drive car, the part number was matched but it is for FWD car, if you shipped to company that suppose to repair try to tell them that you need your original repaired, I have find out hard way , they didn't want to give me another unit , i just went bought new one
