anyone know how to connect daylight driving lights like Canada
Old Sep 6, 2002 | 12:57 PM
A6intel's Avatar
New Member
Default anyone know how to connect daylight driving lights like Canada
dealer will not do it.
Old Sep 6, 2002 | 01:09 PM
chairman's Avatar
Moving?
Old Sep 6, 2002 | 01:39 PM
Stoney's Avatar
Tech Guru
See fog light mod in Tech section.
Old Sep 6, 2002 | 06:54 PM
Doug2.7's Avatar
25 Year Member
Default It is a different wiring harness for CA vs US. but check out the tech section like
Stoney said. It took me all of 30 minutes to wire my fogs so I can use them like driving lights during the day. Also suggest you install the extra rear fog light so you can drive with them on too. That'll add another 30 minutes to your install. Good luck... BTW, the dealer would have to totally modify your wiring harness at great expense to make it like a CA car..
Old Sep 6, 2002 | 10:16 PM
Stoney's Avatar
Tech Guru
Default The rear fog is a bit more involved. Did you...
... do the rear mod? (for those interested: the 2002 and later cars come with both, so this just applies to 2001 and before, BTW.)
I see fog so rarely that I don't think it is much of an issue. And it looked more than trivial to do.
Plus, they are visible almost exclusively from directly behind, so they don't really work as daytime lights for general visibility. The corner lamps that come on with the fogs serve that purpose for me.
Old Sep 7, 2002 | 08:24 AM
Doug2.7's Avatar
25 Year Member
Default Yep, did the rear mod on my '01 2.7 You are correct about seeing
the rear lights only from direct behind but that is what I like. I use them on hwy driving and like the car behind to see me. The rear lights are actually very bright and can be annoying if the car behind is close. JMTC.
AWD2KS4
Feb 19, 2008 08:06 AM
tehA8PIMP
11
Apr 5, 2006 07:01 AM
4.2MingBlue
13
Apr 16, 2002 01:29 PM
Ramon Rosa
29
Apr 9, 2001 07:17 PM
