Best Way to Clean Headlights
Old Apr 3, 2009 | 08:40 PM
teflondevil09's Avatar
New Member
Default Best Way to Clean Headlights
Hi all, I just realized that the inside of the left front headlamp is fogging up with water vapor. What is the best way to clean this out and prevent it from happening again?
Thanks
Old Apr 3, 2009 | 09:15 PM
2.slowT's Avatar
Have you already done the clear corner mod?
Old Apr 4, 2009 | 06:24 AM
mcaanda's Avatar
Check this out - I was just reading this, this morning:
http://www.audizine.com/forum/showthread.php?t=272212
Got a pretty good writeup in there as well.
Old Apr 5, 2009 | 06:27 AM
New Member
Problem is fellas.... those are to reset the look on the outside of the lamp. This condensation is building up on the inside of the headlight fixture... does that make sense?
Old Apr 5, 2009 | 10:56 PM
ArtsA6Q's Avatar
you'll have to remove the headlamps and take apart the entire assembly.
There are rubber o-rings and gaskets throughout the entire assembly - best to recheck each one for a proper fit. If they all look good, it's time to pull apart the cover with some heat (oven) and add a bit more glue before resealing.
It's not a fun task. Most people just 'live with it.'
Good luck.
Old Apr 6, 2009 | 07:38 AM
New Member
does anyone have a good resource on how exactly to remove the assembly and follow through with the heating and resealing process?
Old Apr 6, 2009 | 08:45 AM
01 2.7t's Avatar
If you just want to remove the condensation, take the back cove off and put a blowdryer aimed at the inside of teh housing.... set it on warm or cool air, not hot. that will help to get rid of the condensation.
oakwood-jones
Auto Detailing Discussion
May 12, 2007 06:10 AM
FooFighterRS4
Feb 20, 2007 06:08 AM
gaijin
Jan 5, 2006 06:50 AM
Tennberg
Aug 17, 2003 07:53 PM
yourk
Aug 11, 2002 04:25 PM
