Buggered up remote programming
Old May 31, 2003 | 07:34 AM
skategoat25's Avatar
New Member
Default Buggered up remote programming
I bought a new switchblade remote and got it cut for my '99 A6. I dutifully followed the instructions in the tech section and successfully programmed the new remote.
Then I tried the old remote. No workie. What did I do to the old remote that was working fine?
I tried to re-program the old remote using the same procedure as my first one. No workie.
What the...?
Old May 31, 2003 | 07:48 AM
mbr's Avatar
mbr
Default During step 3, press the unlock button twice....
this happened to me when I programmed my second remote--the new remote worked, but the original one didn't. I tried it again, but pressed the unlock button twice, and both remotes worked. It says this in the last line of the tech instructions. Hope this helps.<ul><li><a href="https://www.audiworld.com/tech/misc13.shtml">Remote reprogramming</a></li></ul>
Old May 31, 2003 | 09:25 AM
New Member
That worked thanks!
Old May 31, 2003 | 05:28 PM
mamizana's Avatar
MBR, on your Avant fobs, does the middle "trunk" button work? Mine doesn't.
Old May 31, 2003 | 07:43 PM
mbr's Avatar
mbr
The button works, but you have to press and hold it for about 5 seconds to work
Old May 31, 2003 | 08:07 PM
mamizana's Avatar
Crazy Germans . . . who knew?
Old Jun 1, 2003 | 05:55 AM
mbr's Avatar
mbr
Default I think it so you don't accidentally open your trunk when the button is in your pocket....
If you accidentally unlock your doors, and don't open a door within 30 seconds, the doors relock, but if you accidentally hit the trunk button on the remote, the trunk is open. I guess they could have just added the automatic relocking feature to the trunk too, but they didn't. Actually, a lot of cars, including American cars, have the 5 second hold button on the remote for the trunk.
Coca-Cola
Oct 26, 2004 08:35 AM
newports4
Jan 8, 2004 06:09 AM
audiringpwr
Feb 5, 2003 09:25 AM
Stang Guy
Mar 19, 2001 07:27 AM
