Built in Equalizer question.....
Old Nov 16, 2003 | 03:52 PM
darren2.7t's Avatar
New Member
Default Built in Equalizer question.....
I have been playing around a little bit with the built in hidden EQ. I was wondering what are some of you guys experiences with this. What numbers are coming up best. Right now I havnt found the right setup. I am no true audiophile, but I do know I like a little more kick in my music. For the Bose setup, what are you finding works best? I've got an XM setup now, so I am switching music styles constantly from Rock, Metal, Rap, to Classical. Any ideas.
Old Nov 16, 2003 | 09:26 PM
Stoney's Avatar
Tech Guru
Default My 2001 sedan is written up...
in the FAQ. You may find this is valid for your car/year.
74384444, see <a href="https://forums.audiworld.com/a6/msgs/78583.phtml">Symphony hidden EQ settings</a> for details of tone control settings etc.
I ended up with this after weeks of experimentation, and have had no inkling to change it since. The first four reflect a desire for more deep bass, a bit less upper midrange, and boost in upper treble, although I combine this with turning the treble tone control down 2 clicks. Found this was the smoothest I could get the treble. The last 4 could easily be 5555, just how I ended up. I usually keep the rear fader down 5 clicks.
If you set the best sound for the front alone, then set it best for the back alone, you will find the bass is too loud when you combine them. I solved this by dropping the rear bass EQ setting (started out at 6444), and by keeping the rear faded down.
Old Nov 17, 2003 | 04:56 AM
TraderAlex's Avatar
Has anybody figured out a setting for Avants? Sedan acoustics are different.
bc0203
Dec 23, 2003 09:19 AM
VenomousA4
Dec 30, 2002 05:04 AM
Drozd
Jun 19, 2001 12:24 PM
Coop's Quattro
Mar 19, 2001 06:33 PM
BOB
Aug 30, 1999 10:55 AM
