Can someone confirm that the 3.0 engine takes 6.8 U.S Qrts...Manual says 6.8 but that sounds way to
Old May 14, 2006 | 02:18 PM
DesmoTesta's Avatar
Default Can someone confirm that the 3.0 engine takes 6.8 U.S Qrts...Manual says 6.8 but that sounds way to
much oil.
I got the oil change already, but ever since been worried about it.
thats almost 7 quarts of oil in just 3000 cc engine
Old May 14, 2006 | 02:21 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Here's a crazy idea:
Pull the dipstick and check.
I usually dump in six quarts, then I run the car few a few minutes and check the oil.
Old May 14, 2006 | 02:40 PM
DesmoTesta's Avatar
Default How can I take some oil out... Oil change was 200 miles ago..dipstick shows higher than where it
shoudl be,,,Also, manual actually says 6.6 Qrts..I remember the tech put in almost 6.9..I have the Mobil 1 bottle and there is very little in it..So, How do I take this oil out..or is .3 qrts not too much to worry about?
Old May 14, 2006 | 02:42 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default How much above the cross-hatched area is it?
How does the run?
Not easy to take oil out.
Old May 14, 2006 | 02:43 PM
DesmoTesta's Avatar
Default Not that much higher, but still, its higher than it should be..Runs fine..I almost never
rev past 3500 RPM anyway..
Old May 14, 2006 | 02:49 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default I probably wouldn't sweat it.
Not good to be over full, but a quarter of a quart isn't a big deal.
Old May 14, 2006 | 02:50 PM
DesmoTesta's Avatar
ok, thx..I will try not to think about it EVERYtime I drive teh car..
Old May 14, 2006 | 03:19 PM
schnellmb's Avatar
Yes, it does take nearly 7 quarts....6.8 is correct.
Old May 14, 2006 | 04:12 PM
Press's Avatar
Fear the Miata!
never go above 3500 rpm's....how slow do you drive...8^)
Old May 14, 2006 | 04:21 PM
Ritz's Avatar
Default Don't worry about it...if it really bothers you....
loosen the oil drain plug and pop it out for about 1/2 second and retighten. That should allow 1/3-1/2 quart out. If it was me, I wouldn't worry about it in the slightest.
Cheers,
