Is this causing my cold start problems? Please help ID broken part
yes the check engine light is on continuously.
The knock sensor and oxygen one were from before the issues started for sure...
5 Faults Found:
16711 - Knock Sensor 1 (G61): Signal too Low
P0327 - 35-00 - -
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-00 - -
16839 - EVAP System: Large Leak Detected
P0455 - 35-00 - -
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0010 1101
5 Faults Found:
P0327 - 35-00 - -
P0441 - 35-00 - -
P0455 - 35-00 - -
Perhaps someone else can chime in on which sensor the B1S1 one is.
After you get the O2 sensor done and get the changeover valve working, I'd erase all the codes, drive the car a couple hundred miles, then pull codes again to see what comes up.
And do give Audi a call at 1-800-FOR-AUDI to find out if your car had the MAF sensor recall work done.
5 Faults Found:
P0327 - 35-00 - -
P0441 - 35-00 - -
P0455 - 35-00 - -
I would replace the mass airflow sensor or at disconnect it for testing. I have had very hard starting A6Qs with bad mass air flow sensors and also bad coolant temperature sensors that did not produce DTCs but still gave the ECU incorrect temperature values.
readings.
not as designed (other inputs or fixed parameters are substituted). This procedure has surprisingly worked for me a number of times. Try it and see what I mean.
