Chips, altitude, and 91 octane fuel...
I know pinging is possible with a chip and 91 octane or less fuel. Is pinging necessarily bad? or basically just annoying?
I live in Colorado where I am constantly at high altitude and cannot get above 91 octane fuel. Should I be concerned when chipping my 2.7T 6spd?
Thank you for any input,
Eric.
More octane makes fuel burn slower. This allows you to spark earlier and generate more power through the early (important) part of the power stroke. Octane reduces volatility.
At altitude, the reduced air pressure and therefore reduced amount of oxygen in the cylinder charge reduces the burn rate. Thus, 91 octane can work as well as 92 or 93 sometimes at high altitudes. I think this is why you get lower octanes available at altitudes.
Problem is, a turbocharger (or any kind of supercharger) can compensate for altitude by packing in the air and fuel. This essentially returns conditions to sea level conditions. Thus, your 91 octane isn't enough for a 92 octane engine any more.
Now, on top of that, some chip manfacturers get their power (not so much on computer controlled turbos, like Audis) from changing the fuel mixture profiles in the chips. Apparently engine chips have several profiles for different altitudes. Some chip upgrade companies change all the profiles (esp. sea level) to be the one which puts in the most fuel. Thus, you no longer have any altitude adjustment in your computer and your car can therefore run poorly at altitudes the chip company didn't test at.
I'm not ascribing these problems to any particular companies.
If it were me, and I had a 2.7T in Denver, I would wait for an altitude compensated or "no ping" chip. Or request one. Basically, they can just not retune for 92 Octane. www.giacusa.com has these for the 1.8T engine, perhaps they can make one for the 2.7T.
By using higher octane these become less of an issue has the actual rate at which higher octane fuels combust is slower. This in turn allows you to have higher boost levels and hence more power.
Higher boost also increases the temperature of the incoming air/fuel charge. This also leads to detonation as well. That is why there are charge air coolers (aka intercoolers) that cool the incoming air reducing the thermal loading on the engine. Heat is the ENEMY of turbo motors. An issue that you run into a higher altitude is that most turbos are not referenced to absolute pressure. Typically all this means is that you will not make as much HP as you would at sea level. Fortunately turbo cars suffer less due to increases in altitude than do normally aspirated cars.
This is a very quick and dirty explanation of it. If you want a more detailed explanation including the thermodynamics behind it I will be glad to supply them.
On my annual August climbing trips to Wyoming, I always had to stop for gas in Salt Lake. There the premium gas was lower octane than in Oregon (Federal law sets the permissable octane in "Premium" gas based on the average altitude of the state!) and my poor car could barely make it up the mountain past Park City. It would knock dreadfully (no knock sensors then) at anthing near full boost. I'd creep up the mountain in the right lane at about half throttle.
I'd be careful about overboost if I lived at high altitude.
But if I lived at altitude, I would demand a "no ping" chip instead of relying on the systems which were designed as backup to work full time.
Besides, the backup plan in the ECU may be to reduce boost to almost nothing or nothing (in fact, the manual says as much). So you may find that your car with a chip performs worse at altitude than if it didn't have a chip. That's fine unless you happen to spend a lot of time at altitude.
I think is about what Ed Slaughter said also.
I was wondering if anyone in Colorado with a "chipped" Audi could provide some feedback. Is it a "special" chip or a standard chip from one of the chip makers?
Is there pinging? Any other concerns?
I know Boulder Audi Tuning "chips" Audis, I'll ask them as well. I'll also talk to some of the chip sellers (APR, Garrett, etc...), but real world info is appreciated. Thanks again for all of the help,
Eric.<ul><li><a href="http://www.fastaudi.com">Boulder Audi Tuning</a></li></ul>
