Computer bug?
Old Sep 30, 2007 | 01:15 PM
Max - A6 - Ottawa's Avatar
New Member
Default Computer bug?
It all started with intermittent problems with the remote trunk opening. Then it changed in having ABS and ESP lights on from time to time. Finally it transformed in intermittent brake light ON(in the instrument panel) and beeping. Vag gave the error:
17087 - Brake Switch (F): Electrical Malfunction
P0703 - 35-10 - - - Intermittent.
Replaced switch: last problem still there. Any ideas?
Old Oct 1, 2007 | 04:50 PM
April's Avatar
AudiWorld Uber User
Default How old is the battery? Seems like odd intermittant problems sometimes show up when
the battery is on the decline.
Old Oct 2, 2007 | 12:36 PM
New Member
Default Re: How old is the battery? Seems like odd intermittant problems sometimes show up when
Battery seems to be fine 12.4V (engine off). I tried playing with the ABS module: I don't know what happened but I had to recode it. Could it lose data by being accessed? Anyway, ESP and ABS panel lights were on and they went off after a few minutes of travel. The beep and the brake sign still comes on blinking from time to time but no error codes.
Old Oct 2, 2007 | 01:11 PM
April's Avatar
AudiWorld Uber User
Default If you search the forum, you'll see that sometimes the battery gives no other warning
of pending failure other than some random electrical/electronic faults. Otherwise I would go looking at battery connections and grounds.
AZC
Q7 MK 1 Discussion
Sep 2, 2020 12:20 PM
audijim113
Jan 22, 2018 08:21 AM
alexmwaniki
Apr 22, 2017 10:10 AM
jmmillerfzr
Jan 21, 2015 03:48 PM
T-Rex
11
Aug 4, 2010 12:37 PM
