electronic instrument cluster replacement
Old Feb 27, 2009 | 11:34 AM
pverba's Avatar
Default electronic instrument cluster replacement
<center><img src="http://pic.leech.it/t/bd432/95e0ca2picture002.jpg"></center><p>
Just had electronic instrument cluster [part no. 4B0920980LX] replaced on 2000 A6.
The new center display has: a]a slightly lighter red background behind the red numbers/letters, b]which becomes black when you look from a side angle, c] a permanent horizontal black line [2 or 3 lines wide] just above red partition line below radio info and, d]also, when the display is turned off via the wiper control arm button, the background of the radio info section goes black but the rest of the display background stays red. [The dash brightness adjustment doesn't help, but does change the intensity somewhat.]
This doesn't seem how it should be. Any ideas appreciated. Maybe software upgrade is required?
Thanks.
Old Feb 27, 2009 | 11:38 AM
Grapeking's Avatar
25 Year Member
Got a picture for us??
Old Feb 27, 2009 | 11:47 AM
Whitjr's Avatar
Where did you get the work done? DIY w/ sending out your old cluster?
Old Feb 27, 2009 | 12:28 PM
30V-6's Avatar
tracking.
Old Feb 27, 2009 | 12:43 PM
baco99's Avatar
New Member
Default is there any way to repair, not replace, the display?
in saab SID displays the culprit is a lose ribbon wire feeding the LED display. has anyone experimented with this on the A6?
Old Feb 27, 2009 | 01:17 PM
pverba's Avatar
Default Re: electronic instrument cluster replacement
Here's a picture. You can see the red background and the black dead?] line near the top.
Work was done by an independent mechanic - replacing entire instrument cluster, not just a chip, display, etc. Local Audi dealer and online Audi customer care can't say if this is how it's supposed to be. Just doesn't make sense that it should be like this; especially that from a side angle, the background is black - as if something is reversed, but the electrical connections can't be re-attached incorrectly.
Old Feb 27, 2009 | 01:32 PM
LIRS6's Avatar
no pic
Old Feb 27, 2009 | 05:16 PM
audifirst's Avatar
Default Looking at your photo, looks like this cluster display is defective
<center><img src="http://pictureposter.audiworld.com/14332/img_1505.1.jpg"></center><p>
you need to ask your mechanic to get you another one, the one you have is bad,
Old Feb 27, 2009 | 05:23 PM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
Default Take it back and tell them to do it again with a new cluster.
It was either done wrong, effed up, or was bad to begin with.
Old Feb 27, 2009 | 05:59 PM
Grapeking's Avatar
25 Year Member
2nd. Bad repair, they need to fix it properly.
