Error codes feedback?
Old Sep 26, 2017 | 08:51 AM
Hitman47's Avatar
Default Error codes feedback?
P0431 Catalyst efficiency code
P0442 Small evap leak
P0491 Secondary air flow problem bank
P0492 Secondary air flow problem bank
Are these all SAI related or what are some thoughts on what these 4 would likely entail to have corrected? Thanks, all!
Old Sep 26, 2017 | 02:26 PM
Harleyguy's Avatar
Probably all related. Secondary air leak could be the air pump, a vacuum line(s), bad fuel filler cap, and numerous other smog type components. Start by looking for cracked, leaking or otherwise compromised vacuum lines.
Old Sep 26, 2017 | 02:48 PM
Hitman47's Avatar
Thanks, Harleyguy. Yeah, I read a DIY on the forums of replacing the SAI pump only to find out it simply needed a new bearing (i think it was) and has had no issues since. So, am hoping that is the case here, but didn't know if anyone was super savvy on these codes to see that it is indicating anything else specifically or not. Thanks for the input!
Old Sep 27, 2017 | 11:36 PM
Giedzka's Avatar
Hello guys, I m new here, so sorry for my bad englsh I got my audi a6 with 2.7bt engine. Yesterday we replaced old egt sensor schemes with the new ones from sidmotorsports.pl. The egt fault code disapeared and know I got 8 fault codes left. From what I should start? one of my friends is suggesting to check whole vaccum system, but maybe its something else? I'm adding the fault codes:
8 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 35-00 - No Activity
16542 - Oxygen (Lambda) Sensor B2 S2
P0158 - 35-00 - Signal too High
17763 - Cylinder 1 Ignition Circuit
P1355 - 35-10 - Open Circuit - Intermittent
17772 - Cylinder 4 Ignition Circuit
P1364 - 35-10 - Open Circuit - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
Readiness: 0110 1101
Old Sep 28, 2017 | 12:25 AM
4Driver4's Avatar
Tech Guru
Tech Guru
8 Faults Found:
16687 - Cylinder 3
16685 - Cylinder 1
16686 - Cylinder 2
Cylinder one bad coil?
Old Sep 28, 2017 | 12:36 AM
Giedzka's Avatar
Well I'm gonna check that one, but what about the others?
sugaryling
Audi 100 / A6 (C4 Platform)
Mar 25, 2012 12:03 PM
edel
Jun 2, 2011 02:32 PM
sjal2
Nov 16, 2005 07:41 AM
bobcaTT
May 30, 2005 07:37 AM
Produce
Aug 21, 2001 10:11 AM
