EZ Pass doesn't work through new windshield!
Old Dec 8, 2006 | 04:05 AM
Li3ny's Avatar
Default EZ Pass doesn't work through new windshield!
Replaced the windshield last friday with a Pilkington, which is what it had in it already. Except this one has some kind of special laminant that my last windshield did not have.
I contacted EZpass on monday to see what the problem was, they told me that my tolls were going through and to ignore the flashing red stop light. They claim the problem is that it's not velcroed to the windsheild. (I guess I'm some kind of idoit that can't hold the thing in the correct direction.) So yesterday I figured what the heck, and I held my arm & EZpass out the window as an experiment. Sure enough it works!
So I have temporarily mounted it to my sunroof and it works fine now. I guess I'm just going to have to experiment to find the best usable location.
I can't wait to see next months statement so I can see if I was actually charged. The EZpass attendant said as long as I'm driving my own car that the tolls would go through. So I guess that means they read plates.....but my plate is sprayed so you can't take pictures of it....and I have limo tint over the cover. Hmmmm?.! It doesn't make much sense to me, especially since I called EZpass right after I drove through the toll. How could a plate get processed that quickly? I really don't see it possible.
Old Dec 8, 2006 | 04:13 AM
GDawgA4's Avatar
Default Usually those laminate windshields have "zones" which allows IR to pass through, usually
next to and behind the rear view mirror. If you park it under the sun and look at various angles at the windshield, you should be able to spot these zones (look sorta bronze almost) if the windshield has it.
If not, you'll have to either keep using the pass out the window or get the license plate mounted one.
Old Dec 8, 2006 | 04:20 AM
Li3ny's Avatar
Good lookin' out! Thanks!
Old Dec 8, 2006 | 04:28 AM
GDawgA4's Avatar
No problem
Old Dec 8, 2006 | 05:14 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Tape it to a stick and poke it out the sunroof at each toll.
and yes, they photograph plates. It will be interesting to see what sticks for charges.
absolutcq20v's Avatar
Default I have had the same sorta problems...
I got my windshield replaced with a Siglia(?) and installed the EZpass transponder behind the rear view on the pass. side (I couldn't see if from the driver's seat).
I noticed that the routine toll booths I travelled through wouldn't light up as I passed through, I would check online and, sure enough, the tolls hadn't registered (they appear within the same day to 2 days later).
Oddly enough, it worked when I had it sitting on the left portion of the dash, label side down (velcro up). I even went so far as to mount it under the dash, behind the instrument cluster, so it's completely stealth...it's worked every time since then. (??)
PS - I have found that the speed threshold is about 32 or so for most non-high speed booths. :P
Sooo, I can't help...but I can waste your time with a related story. :P
Old Dec 8, 2006 | 05:48 AM
5speed6  v.2's Avatar
Member
Do you run with a front plate? They have a pass that mounts to it.
Old Dec 8, 2006 | 05:52 AM
Li3ny's Avatar
Default I could just put my spoiler back on and tape it to that.
<center><img src="http://pictureposter.audiworld.com/81774/audisp_001.jpg"></center><p>I'm going to get you a picture of your stick idea, because it's so damn funny! Could you imagine seeing that happen in front of you. I would laugh my a$$ off!
Old Dec 8, 2006 | 05:56 AM
Li3ny's Avatar
Behind the cluster is so crazy that I like it.
Old Dec 8, 2006 | 05:57 AM
GDawgA4's Avatar
I never woulda thought it could work like that.
