Getting a re-occuring cel and fault code...
Old Oct 26, 2006 | 03:57 PM
WaggsA6's Avatar
New Member
Default Getting a re-occuring cel and fault code...
16515/P0131/000305 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
Possible Causes:
Wiring to Oxygen Sensor Bank 1 Sensor 1 faulty
Possible Solutions:
Check Wiring to Oxygen Sensor Bank 1 Sensor 1
Check Oxygen Sensor Bank 1 Sensor 1
Perform Aging Check
Does this probably mean I'll need to replace an oxygen sensor?
Which oxygen sensor is it if so?
Thanks,
Old Oct 26, 2006 | 04:09 PM
RichPugh's Avatar
Bank one, sensor one = right (passenger) side, before catalyst
Old Oct 26, 2006 | 04:14 PM
WaggsA6's Avatar
New Member
ok, thanks
Old Oct 26, 2006 | 04:18 PM
RichPugh's Avatar
welcome
Old Oct 26, 2006 | 08:16 PM
baskinblack4.2L's Avatar
Default it is the top most o2 sensor you can see it with the hood popped. I replaced both of mine
There cheep and worth replacing both. As the sensor 1 plays a role in the fuel mixture and can effect performance and gas mileage.
The dealer might be expensive. I got mine from Vast performance they were quite a bit less
MikeReno13
Feb 26, 2020 07:41 AM
garysaunders85
Nov 21, 2018 07:17 AM
Kahuna-Big
Dec 18, 2009 06:23 PM
I AM 2ks4
Jan 30, 2005 01:30 PM
deras22
May 8, 2004 04:47 AM
