HELP... cam timing adjuster problem...
Old Apr 7, 2010 | 02:27 PM
  #11
MisterG's Avatar
Do not worry so much about the marks on the cam caps when counting the links in the chain. Focus on the number of barrels between the depressions in the cam sprockets. Once you get it to 16, pick up both cams, keeping them taut so you do not jump teeth due to slack, and place them in the head. When placing them in the head, find the position where the cams sit flush, and if you have to rotate cw or ccw to do so, make sure you turn them together so you do not lose your 16 links of separation. See my similar problem and 4Driver4's response in the following post:
Here
Not sure if the same applies to the 4.2.
Old Apr 7, 2010 | 03:57 PM
  #12
Bx3's Avatar
Bx3
Thanks. Got it together with 16 links, rotated the motor once and everything lined up. Now to get it all buttoned up and fire her up...I hope...
vwills1.8ta4
1.8T Discussion
Oct 6, 2013 09:59 AM
Shan H
May 27, 2008 07:04 PM
jlag
13
Dec 10, 2007 07:25 PM
Bryans12v
30v V6 Discussion
Mar 8, 2005 11:54 AM
the director
Sep 11, 2004 09:36 AM
