HELP -- massive coolant leak - back of the engine
Old Jun 1, 2026 | 08:36 PM
soundquest's Avatar
Default HELP -- massive coolant leak - back of the engine
1999 A6 AWD 2.8L Base. Catastrophic heater hose breakage (can't tell if heater inlet hose or return hose) at the back of the engine down below the throttle body. Flange plastic connector snapped with the plastic barb still inside the hose with the AUDI clamp ring on the end of the hose. I am specifically looking for a good DIY write-up on this repair and also for the part numbers both for the return and the supply hoses so I can knock both of them out at the same time (assuming they are in the same vicinity). Thanks in advance.
Old Yesterday | 06:12 AM
soundquest's Avatar
BUMP. Anyone? 1999 AHA engine -- heater hose. Back of the engine. Do they sell the flanges separately since I don't have to buy/install the entire hose? I have searched high and low -- for such a common problem, there is very little information available.
Old Yesterday | 09:12 AM
dgmueller's Avatar
Default Check another forum
Sorry to hear that. I am not sure re question, but suggest finding the forum for your car. This is for the C5 platforms.
Old Yesterday | 12:09 PM
dgmueller's Avatar
Sorry, this maybe the closest forum here. Apologies. If it is like an A4 I had, there is a plastic connector at the back of engine that could break or the o ring leaks. Might need a mirror to check it out. A temp sensor was also part of that connection on the A4.
jaxfljustin
Oct 27, 2024 11:33 PM
Rob03
Audi allroad
May 24, 2022 02:12 PM
m1964
May 11, 2021 09:36 AM
Johnbach
Mar 14, 2020 03:54 PM
J. Cain
Audi A3 / S3 / RS 3
May 7, 2019 11:08 PM
