I would like to beat the dead horse for a moment...Timing belt
Old Mar 26, 2004 | 08:06 AM
TTS_4_to_A6's Avatar
Default I would like to beat the dead horse for a moment...Timing belt
I have almost 70,000 miles on my A6 2.8q and was thinking of needing to do the timing belt. I was told it isn't necessary to do until a little ofer 100,000 miles. I have seen around here that around 80ish is good? I plan on driving the car for at least 4 more years.
Should I wait longer?
Thanks
Old Mar 26, 2004 | 08:29 AM
screwynewy's Avatar
Default Go ahead and get it done. Since you plan on keeping the car for that much.......
longer, it will give you peace of mind knowing that its not going to break and cause serious engine damage. You probably know the routine, water pump, belts, tensioners etc.etc. should all be done at the same time.
Old Mar 26, 2004 | 09:09 AM
Eric 2.7's Avatar
Default I'd do it at 75k along with the serp belt, thermostat & water pump
The official maintenance interval for the timing belt is 105k, but obviously as you get closer to that point, there is a higher possibility for failure. To me an interference engine warrants some conservativism.
Since the serp belt needs to be done at 75k, I'll do the timing belt (and tensioner), water pump and thermostat at that time. Not a bad DIY job either. Some good resources in the tech section.
Old Mar 26, 2004 | 09:13 AM
gietl's Avatar
It should be a DIY job if you are so inclined..save some $$$$
Old Mar 26, 2004 | 09:26 AM
Thanks for the info, will be making my appt soon.
Old Mar 26, 2004 | 10:12 AM
Eric 2.7's Avatar
DIY . . . DIY . . . DIY . . . You'll love your car more after you've taken it apart.
Old Mar 26, 2004 | 10:33 AM
gietl's Avatar
Default We did 6 B5 timing belts at once a month ago.
They were all 1.8Ts (both passats and a4s) but I would expect the 2.8 to go just as smoothly.
You can get a whole kit from ECS for a reasonable price, about $250+ depending if there is a sale or not. Sure beats the $700+ a shop or dealer might charge you.
It's very labor intensive hence the high price from a shop. You would need to expect to give up an entire Saturday or Sunday to do it.
Old Mar 26, 2004 | 05:47 PM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Default Complete list of what to do / consider doing
<ul><li><a href="https://forums.audiworld.com/a6/msgs/360657.phtml">is here. Also some good ref links.</a></li></ul>
Old Mar 26, 2004 | 06:19 PM
s4master1's Avatar
Default do it now
don't take the chance
Skyline411
9
Sep 4, 2005 04:12 PM
tragopan86
Mar 13, 2003 06:56 AM
BukkakeRocky
12
Jul 15, 2002 12:10 PM
UofM_Audi
Audi 100 / A6 (C4 Platform)
Mar 21, 2002 11:26 AM
LifeinAudi
Feb 12, 2002 09:13 AM
