Removing plugs from the CCM
Old 04-28-2014, 04:48 PM
ather's Avatar
Default Removing plugs from the CCM
Hi All,
After the water electrical short from the battery removal, the sunroof stopped working as well as the rear passenger window and door lock. After a some research, it pointed to the comfort control module. I read that if you pull out the plugs and reconnect them after cleaning the pins, it should work again. The #14 fuse looks good btw.
So I pulled out the CCM and opened it up. My question is, how do I take the plugs out? They don't look like any other plugs I've seen and I don't want to use brute force to remove them. Is there a specific technique to removing them? Thanks in advance.
Old 04-28-2014, 05:16 PM
ather's Avatar
Quick update, got the plugs out, cleaned the pins and put them back on again. Still not resolved. Time to keep looking for solutions. Any ideas?
Old 04-29-2014, 07:32 AM
SloopJohnB@mac.com's Avatar
Get a used CCM and try it.
Old 04-29-2014, 07:40 PM
HereInOhio's Avatar
Pry open the CCM case and visually look at the board. If it's water logged you'll be able to tell. Doesn't mean it's not bad if it's not corroded but if it is you can bet on it.
Old 05-05-2014, 07:25 AM
ather's Avatar
I opened it up and it no corrosion or any sign of damage. I'm guessing it could be a short. Also, I've read somewhere there is a relay under the steering wheel in the dash as well for it. I also found a used CCM for $70 online so I may just bite the bullet and get it to try it out.
Thanks very much.
GOFASTT
05-30-2007 05:42 PM
pennstatefan664
08-21-2005 11:52 AM
sridhar
04-07-2005 04:45 PM
TwinTurboTerror
9
01-24-2004 10:04 PM
moribundman
04-21-2003 10:30 AM
Quick Reply: Removing plugs from the CCM
