Intake issue - throws codes / Lean and mixture
1 - Anyone think the cracked intake is the issue?
2 - I don't see any electronics connected - BUT - there is a small hose (metering kind of thing?) that comes off at one point close to the throttle body that is connected to some electronics - I assume at mixture sensors.
3 - I can't find any parts online that look like my intake assembly. There are some after market parts but I don't see any place for any sensors or any connections for hoses that would connect for sensors.
I'll include pics for clarity her. The cracked parts as you'll see are the ones covered I duct tape.
Anyone have any advice on how to move forward? I'd appreciate it very much.
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 3C 42 44 46 52 53 55
56 5F 62 6C 72 8F 90
VIN: WAUG Mileage: 174274km-108288miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CTUA) Labels: None
Part No SW: 4G0 907 551 D HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0006
Revision: --H07--- CVN: 4C7FB7FB
Coding: 0A2A0032052601060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551D 001007
ROD: EV_ECM30TFS0214G0907551D.rod
VCID: 2A0DFE8D9C7EB81BD95-807E
VINID: 9D19575D1593A147810C0040082604AB9B
7 Faults Found:
6352 - Cylinder 3
P0303 00 [036] - Misfire Detected
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 174259 km
Date: 2021.09.26
Time: 15:48:36
Engine RPM: 1904.00 /min
Normed load value: 94.5 %
Vehicle speed: 85 km/h
Coolant temperature: 63 ∞C
Intake air temperature: 31 ∞C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.812 V
Unlearning counter according OBD: 40
Engine speed: actual: 1952 /min
MAF_ENVD: 566.49410 mg/stroke
Coolant temperature (unfiltered): 63.75 ∞C
Engine: operating status: PL
T_AST_ENVD: 154.20 s
Vehicle speed: actual: 85 km/h
6238 - Fuel Rail/System Pressure
P0087 00 [039] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 174274 km
Date: 2021.09.26
Time: 16:50:09
Engine RPM: 688.00 /min
Normed load value: 13.7 %
Vehicle speed: 0 km/h
Coolant temperature: 89 ∞C
Intake air temperature: 65 ∞C
Voltage terminal 30: 12.999 V
Engine speed: actual: 704 /min
MAF_ENVD: 168.85882 mg/stroke
Coolant temperature (unfiltered): 89.25 ∞C
FUEL_MASS_REQ_I_CTL_ENVD: 6.281250
FUP_ENVD: 4075.5531 hPa
FUP_EFP_ENVD: 5455.31 hPa
6212 - Fuel Trim; Bank 2 (Mult)
P1130 00 [039] - System too Lean
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 174274 km
Date: 2021.09.26
Time: 16:51:14
Engine RPM: 683.00 /min
Normed load value: 9.8 %
Coolant temperature: 86 ∞C
Intake air temperature: 63 ∞C
Voltage terminal 30: 13.405 V
MAF_ENVD: 92.60000 mg/stroke
Coolant temperature (unfiltered): 86.25 ∞C
Engine: operating status: IS
T_AST_ENVD: 51.40 s
STATE_LS_ENVD[2]: 2
17619 - Secondary Air Injection System: Bank 1
P0491 00 [237] - Insufficient Flow
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 167002 km
Date: 2021.05.04
Time: 08:41:52
Engine RPM: 895.00 /min
Normed load value: 26.3 %
Vehicle speed: 5 km/h
Coolant temperature: 31 ∞C
Intake air temperature: 30 ∞C
Voltage terminal 30: 13.304 V
Engine speed: actual: 896 /min
MAF_ENVD: 272.35293 mg/stroke
Coolant temperature (unfiltered): 38.25 ∞C
Battery voltage: 13.304688 V
STATE_LS_ENVD[1]: 2
17620 - Secondary Air Injection System: Bank 2
P0492 00 [237] - Insufficient Flow
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 167002 km
Date: 2021.05.04
Time: 08:41:52
STATE_LS_ENVD[1]: 2
6506 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 41
Mileage: 167002 km
Date: 2021.05.03
Time: 15:22:32
Normed load value: 21.6 %
Coolant temperature: 82 ∞C
Intake air temperature: 66 ∞C
Voltage terminal 30: 12.085 V
Engine speed: actual: 672 /min
Coolant temperature (unfiltered): 90.00 ∞C
Engine load: 7.812500 %
Vehicle speed: actual: 0 km/h
7948 - Cylinder Disabling
P130A 00 [036] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 174259 km
Date: 2021.09.26
Time: 15:48:37
Engine RPM: 1938.00 /min
Normed load value: 81.2 %
Coolant temperature: 64 ∞C
Engine speed: actual: 1984 /min
MAF_ENVD: 593.72940 mg/stroke
Coolant temperature (unfiltered): 64.50 ∞C
Vehicle speed: actual: 86 km/h
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16--- CVN: 06AF4385
Coding: 000002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 2D07F591AD90AF233C7-8078
2 Faults Found:
12446 - Valve for Transmission Fluid Cooler
P2753 00 [175] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 81
Mileage: 169379 km
Date: 2021.06.13
Time: 16:09:45
Voltage terminal 30: 13.466 V
Voltage supply of regulator valves: 13.431 V
Current N215 Pressure control valve 1: 850.0 mA
Current N218 pressure reg.valve 4: 50.0 mA
Current N216 pressure reg.valve 2: 850.0 mA
Current N233 pressure reg.valve 5: 50.0 mA
Current N217 pressure reg.valve 3: 850.0 mA
Current N371 pressure reg. valve 6 lock-up clutch: 50.0 mA
Current N443 pressure reg.valve 7 main pressure: 850.0 mA
Current solenoid: 0.0 mA
Engine RPM: 719 /min
ATF temperature: 65 ∞C
Control Module temperature: 64 ∞C
selected gear: 1
M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
M015_Time Normal Mode: 150 s
M019_Time Since Reset: 7650 ms
12448 - Valve for Transmission Fluid Cooler
P2753 00 [040] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 240
Mileage: 166996 km
Date: 2021.05.03
Time: 14:31:01
Unlearning counter according OBD: 37
Voltage terminal 30: 12.184 V
Voltage supply of regulator valves: 12.185 V
Current N215 Pressure control valve 1: 0.0 mA
Current N218 pressure reg.valve 4: 0.0 mA
Current N216 pressure reg.valve 2: 0.0 mA
Current N233 pressure reg.valve 5: 0.0 mA
Current N217 pressure reg.valve 3: 0.0 mA
Current N371 pressure reg. valve 6 lock-up clutch: 0.0 mA
Current N443 pressure reg.valve 7 main pressure: 0.0 mA
Engine RPM: 0 /min
ATF temperature: 39 ∞C
Control Module temperature: 38 ∞C
selected gear: without traction
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Coasting
M015_Time Normal Mode: 92 s
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 44A78F0122E5F1805B00
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3635DAFD58C6ECFB4DD-8062
1 Fault Found:
0606 - Tire Pressure Warning
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 172
Mileage: 173727 km
Date: 2021.09.06
Time: 15:45:46
VzRef: 2B
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 01
F-Type: 2A
Uz: B7
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
Component: BCM2 2.0 H33 0433
Revision: 00002001
Coding: 0DA82046000000000000
VCID: 7BA30BC923E4F193F23-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 2313000032152006
No fault code found.
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AH HW: 4G0 820 043 AH
Component: KLIMA 2 ZONEN H11 0086
Serial number: 16031300110138
Coding: 6601201849
ASAM Dataset: EV_AirCondiBasisUDS 002044
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 65974DB1B5E05763347-8030
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001529595
Coding: 06002091063C9FE08100088380003908CF9CD208A609022100 0004406000
VCID: 6FBB2F99679C9D334EB-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 130227 H36 0080
Serial number: 130305003711
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21076982
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 04 03 2013 00000300
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 0D080B96000000000001
2 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 204
Mileage: 167481 km
Time Indication: 0
Date: 2021.05.12
Time: 13:26:00
02258 - Door Opener Transmitter
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 167481 km
Time Indication: 0
Date: 2021.05.12
Time: 13:26:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061307101032
Coding: A8C305
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BF29E171288BC358F-8024
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8002V6FZ
Coding: 303234373131303030314A55304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 3333E3E94BB4F9D36A3-8066
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H11 0046
Serial number: 6940000Y130000RU9K0E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB401A50EP29GG5
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB401A50EP2G0S9
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB401I50FFIM9HN
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB401E50FFICODL
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400A50DLUJ1BS
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400Q50DLUJI9H
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20130315000560
Coding: 000034
VCID: 3039ECE5BA22C2CB171-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0010
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 983 E HW: 4G8 920 983 E
Component: TBenUsa H79 0515
Revision: 28460208 Serial number: 658080313596056
Coding: 0BE609040B41D705020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
VCID: 372BD7F95FCC15F356B-8062
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000858834
Coding: 00CD073000
GVL: FDA1E80CDE62600D0000
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS_001_AU57.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 4735060203
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 13010600000000000231
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000053800341
Coding: 00581B0000006001000001010101102030303232203232
VCID: 77AB17F91FCCD5F396B-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA8202V7UV
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0060
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0000001
Shop #: WSC 28588 001 1048576
VCID: 3039ECE5B622C2CB171-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0060
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F15.03.1300H03000AMS15760ˇ
Subsystem 4 - Serial number: S15760ˇ
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F17005E00628002000012
VCID: 47CBA7392FAC657326B-8012
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0028306360
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323DE6EDB4AEF0DB615-8066
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0302599471
Coding: 0106023A00FA408580B0080402050E07000000000000000000 0000000000
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 2 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO20756543
Coding: 101F00
5 Faults Found:
02901 - Lamp for Brake / Blink / Parking 2; Left (M72)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 148
Mileage: 166997 km
Time Indication: 0
Date: 2021.05.03
Time: 14:35:41
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 181
Mileage: 167002 km
Time Indication: 0
Date: 2021.05.03
Time: 14:42:33
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 181
Mileage: 167002 km
Time Indication: 0
Date: 2021.05.03
Time: 14:42:54
03233 - Controls for Garage Door Opener (E284)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 204
Mileage: 167481 km
Time Indication: 0
Date: 2021.05.12
Time: 13:26:33
02902 - Lamp for Brake / Blink / Parking 2; Right (M73)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 185
Mileage: 174097 km
Time Indication: 0
Date: 2021.09.23
Time: 11:35:28
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0507
Coding: 011F17005E00628002000002
VCID: 46D5AA3D28A67C7BDDD-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000623270
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B03FB899384A113223-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 130314-0002-054
Coding: 1221A6101002A500
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU21.rod
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156CW0D7704640
Coding: 020007020100000001
VCID: 241110B5FEDA6E6BE39-8070
1 Fault Found:
00418 - Front Right DSP Mid-Bass Speaker (R102)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 141
Reset counter: 148
Time Indication: 0
Freeze Frame:
Voltage: 12.60 V
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 H HW: 4G0 035 746 B
Component: H-BNT-NA H50 0902
Revision: -------- Serial number: 194C50D7526787
Coding: 050200000003E0EF55128B3E00000003100001000000000000
VCID: 2C01F895960AA62B2B9-8078
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD000YBXK
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349MCE0006A
Subsystem 4 - Part No: 8R0 060 961 E
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0507
Coding: 010F17004000628002000002
VCID: 49CFA10139B8930330F-801C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J32G35Z
Coding: 1080004
VCID: 26150ABD84E69C7BFDD-8072
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313FE9E1B1A8CBC318F-8064
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:07, VBatt start/end: 14.0V/14.1V)-----------
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 10: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 36: DTCs cleared
Address 3B: DTCs cleared
Address 3C: DTCs cleared
Address 42: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 52: DTCs cleared
Address 53: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 5F: DTCs cleared
Address 62: DTCs cleared
Address 6C: DTCs cleared
Address 72: DTCs cleared
Address 8F: DTCs cleared
Address 90: DTCs cleared
VCDS Release 21.9.0: SRI Reset-SRI1.CLB
Control Module Part Number: 4G8 920 983 E Labels: .*4H0-920-xxx-17.clb-SRI1
Component:TBenUsa H79 0515, Coding:0BE609040B41D705020000
Operation: Please select an operation
Channel Description Current val. New val.
IDE00342-ESI: Resetting ESI ESI: Service Reminder Status no warning ---
IDE00510-ESI: distance driven from inspection ESI: Distance since Inspection 8300 km ---
IDE00511-ESI: time from inspection ESI: Time since Inspection 165 d ---
IDE00515-ESI: oil quality ESI: Oil Quality poor oil quality ---
IDE00517-ESI: soot entry ESI: Soot Quantity 0 km ---
IDE00518-ESI: thermal load ESI: Thermal Load 19400 km ---
IDE01153-SIA: maximum value of distance to service SIA: Maximum Distance to Service 16000 km ---
IDE01154-SIA: maximum value of time to service SIA: Maximum Time to Service 365 d ---
IDE03349-FIX:Max. distance driven until next mileage-related inspection FIX: Maximum Distance to Inspection 16000 km ---
IDE03350-FIX: Maximum time until next time-dependent inspection FIX: Maximum Time to Inspection 365 d ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection FIX: Distance since Inspection 24300 km ---
IDE03352-FIX: Time since last time-dependent inspection FIX: Time since Inspection 459 d ---
VIN: WAUGGAFCXDN130102 Mileage: 174274km-108288miles
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
56-Radio -- Status: OK 0000
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 174274 km
Date: 2021.09.26
Time: 17:22:14
Engine RPM: 686.00 /min
Normed load value: 24.7 %
Coolant temperature: 93 ∞C
Intake air temperature: 70 ∞C
Voltage terminal 30: 13.913 V
Engine speed: actual: 576 /min
MAF_ENVD: 245.11764 mg/stroke
Coolant temperature (unfiltered): 93.75 ∞C
FUEL_MASS_REQ_I_CTL_ENVD: 10.992188
6208 - Fuel Trim; Bank 1 (Mult)
P1128 00 [039] - System too Lean
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 174274 km
Date: 2021.09.26
Time: 17:23:28
Engine RPM: 706.00 /min
Normed load value: 12.2 %
Coolant temperature: 94 ∞C
Intake air temperature: 71 ∞C
Voltage terminal 30: 14.015 V
MAF_ENVD: 125.28235 mg/stroke
Coolant temperature (unfiltered): 94.50 ∞C
T_AST_ENVD: 2004.60 s
STATE_LS_ENVD[1]: 2
Readiness: 1110 1101
Coding: 000002
Revision: 00002001
Coding: 6601201849
Coding: 0045F7
Coding: 02006D
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 174274 km
Time Indication: 0
Date: 2021.09.26
Time: 17:16:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 148
Mileage: 174274 km
Time Indication: 0
Date: 2021.09.26
Time: 17:16:00
Coding: A8C305
Coding: 000034
Coding: 00CD073000
Voltage stabilizer:
ROD: EV_SARA2.rod
Coding: 0000001
Coding: 101F00
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 174274 km
Time Indication: 0
Date: 2021.09.26
Time: 17:20:58
Coding: 1080004
You probably want:
https://www.audiworld.com/forums/s6-...iscussion-199/
16471/P0087/000135 - Ross-Tech Wiki
You may have a worn camshaft, I have attached the tsb for this problem.
