- Audi A6 C5 How to Replace Oxygen Sensors<br>Step by step instructions for do-it-yourself repairs.
Lambda O2 sensor engine location? V8 4.2!
Did you figure out what vacuum line it is? I can't figure out what it does from the pic.
Here is a good site with info on How to decode OEM VW part number and Audi part numbers, maybe you can ease your worry if the differing O2 sensor numbers were due to a normal revision/upgrade.
MP4.2+6.0, good call on the vacuum lines!
MP4.2+6.0 do I know your name or do we call you MP, sorry if I forgot it because you are really a top contributor to the A8 forum.
This was the other vacuum line broken...
I had 1.8ts and 2.0ts in the past and this engine is a new adventure!
4 Faults Found:
17538 - Fuel Trim; Bank 2 (Mult): System too Lean
P1130 - 35-00 - -
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-10 - - - Intermittent
and now:
1 Fault Found:
P1130 - 35-00 - -
But judging from the 17539 code, you replaced the 02 sensor on the bank that had the broken vacuum line in the picture. So it's likely you still have a broken or leaking vacuum line on that bank you replaced the 02 sensor.
Keep looking.
Keep looking.
I didnt found any other vacuum lines
thanks for your answer!
