Multiple Qs
Old Apr 5, 2011 | 05:18 PM
bullterrierA6's Avatar
Default Multiple Qs
Hi everyone,
New to the site and have a few Qs.
I have had a MIL that has been intermittently on (but now ON all the time) since having a valve cover gasket and Timing belt job done about a year ago.
Just a few days ago I took the car to the dealer and they suggested one of my cats is gone, the other is on its way out and the car needs a torque converter. Looking for a indy shop to see if in fact these things need to be replaced and more importantly fix whatever needs to be fixed so that I can pass inspection this month (4/2011)!
Has anyone had aftermarket cats installed in a 2002 a6 2.7t without problems?
Also I was told the battery likely needs to be replaced soon. Where do you all generally have the battery replaced at aftermarket place? sears? firestone? NTB? Or should I do it myself. I worry that the radio will lock up or I will have other problems if I do it myself.
Appreciate any thoughts or advice!
Steve
Old Apr 5, 2011 | 05:56 PM
radhaz's Avatar
Changing the battery is not difficult, although it's located in a hard to reach spot. If you have a bad back, get help. If you change the battery reasonably quickly, you shouldn't loose the radio. Check your owner's manuals for the radio booklet, it will have the codes.
I bought my battery from NAPA.
Also, if your alternator has never been serviced (new brushes) or replaced, I'd consider that too. Mine lasted about 100k miles.
I would have the codes read and try to understand what they mean, before accepting what your dealer is telling you about cats.
Old Apr 6, 2011 | 09:08 AM
devinsixtyseven's Avatar
The CEL is almost certainly unrelated to the TB/gasket job...sensors and parts age, the light comes on, we replace and move forward...
Autozone will pull the codes for free. Note them, then search on those codes here, and online in general...there are several very good VAG forums.
Unless they're rusted through, cats do not fail on their own (ok, "in general")...that's why those codes are critical. Read up on VAG-COM as well, the cable and software are by Ross-Tech. Consider buying the setup...it will save you money, in the long run.
As far as the battery, don't pay anyone to replace it for you; it is one of the easiest service items on the car. I'd put it in the same category as changing the air filters or the oil...easier than the oil, actually.
Old Apr 7, 2011 | 06:04 PM
Thanks for the responses. I made it to an independent mechanic today and VAG scan found 4 codes:
P18032
P17887
P16805
P17125
Tried clearing the MIL...no luck initially:
P17125 persisted.
Tried clearing it through transmission (interface or window on software as opposed to Electrical section) and it cleared.
I have driven in about 40 miles and so far no return of the MIL. Once it turns on again I will get it scanned to see what code is thrown first since I'm sure that one code is possibly contributing to some of the other fault codes.
Do you all know of specific threads/websites for troubleshooting DTCs?
Thanks again!
Old Apr 7, 2011 | 09:24 PM
Redneck Truck's Avatar
ross-tech.com
Old Apr 8, 2011 | 08:33 AM
massboykie's Avatar
Originally Posted by bullterrierA6
...Do you all know of specific threads/websites for troubleshooting DTCs?
For future searchers....
http://DTCSearch.PlanetVAG.com
16805 P0421 Warm Up Catalyst Bank1 Efficiency Below Threshold
17125 P0741 Torque Converter Clutch Circ Performance or Stuck Off
18032 P1624 MIL Request Sign.active
I need to add the 4th one is and add it to the DB.
17887 P1479 Brake vacuum system malfunction
I would check your vacuum lines as that can potentially cause weird cat codes when "uncounted" outside air is introduced to the system.
Cheers
Massboykie
Old Apr 8, 2011 | 11:11 AM
LEVEL10TRANSMISSION's Avatar
Former Vendor
Cheers
Massboykie
greetings,,, just noticed 2 codes that identify transmission issues,,, po 741 & 1725,,, Level 10 is the audi experts and we can help you with that,,, that is why we are here getting the word out
Old Apr 8, 2011 | 03:29 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Wow. Now that is some good info.
NTRLY.
If you are the "audi experts" why not add some value by explaining the codes instead of just throwing out a vague sales pitch?
Old Apr 8, 2011 | 03:54 PM
2.7Lturbo's Avatar
what word is that? that you are experts at blowing up transmissions? yeah no thanks, youd think we have never been in the supra forums or know how to use google LAWL!
jenkins214
Aug 17, 2011 01:59 PM
gh0st
Feb 1, 2008 12:40 PM
kjb99
15
Jul 23, 2007 02:39 PM
Mica
Jan 9, 2004 09:45 PM
