oxygen sensor replacement procedure?
Thanks. Brian
Good luck.
Note: I've finally made friends with the dreaded pinch bolt. I now use MAPP gas and heat the area around the bolt. Then I use an impact wrench to turn the head of the bolt after it was heated. (Don't be bashful with the gas, at least 1-2 min of direct heat. Pprotect the upper link boots with a scrap piece of metal while heating - I used an old license plate.) I've done two pinch bolts like this recently and it went much easier than ever before. Probably a good idea to clean out the hole after removing the bolt.
Jim
'03 A6 Avant
